Cooling system problems sn95 help!
Old Mar 25, 2016 | 04:21 PM
1995Sn95's Avatar
1995Sn95
Default Cooling system problems sn95 help!
I have a 95 gt 5.0. last week I let the car idle for about 20 minutes and when I came back to it, the car was over heating and the coolant was gushing out the resivour and out of the radiator cap. I replaced the thermostat and the radiator cap and drove it down the highway (1 hour trip) with no problem. I got back to town, made one trip across town and it did it again. Fan is kicking on, so I figured it was a head gasket. I did a combustion gas test on the radiator and it passed; no combustion gas present. I am at a loss as to what this could be. Please help!
Old Mar 25, 2016 | 05:03 PM
Granatelli Sales's Avatar
Granatelli Sales
Former Sponsor
Could be the water pump. Also, you should do a leak down test to check your cylinders for leakage. If you have an internal engine issue such as a head gasket failure it will show in the leak down test.
Old Mar 28, 2016 | 06:37 AM
88 orangepeel notch's Avatar
88 orangepeel notch
Welcome to the forum, but just for future reference, these Tech questions should go in the Tech Section. Just to keep the forum organized.
You said the fan kicks on, which I'm assuming means someone put an electric fan on. Is it big enough to move enough air ? What's the radiator look like inside, clean or partially plugged ? Start the engine cold with the cap off, when the thermostat opens, can you see the coolant flowing ?
I doubt it would be a bad head gasket, as you have an iron block, with iron heads. Not that its not possible, but not as likely as aluminum heads.
I'd start a new thread in the 79-95 Tech section, and we'll get this figured out over there.
lazer
24
May 10, 2016 06:23 PM
scooter3
Mar 11, 2016 09:01 AM
spencerlozeau@comcast.net
Mar 11, 2016 08:02 AM
johnnyreb17
Mar 2, 2016 06:45 AM
Taylor D
Feb 26, 2016 07:41 PM
