fuel help
Old Aug 5, 2017 | 11:44 AM
bullardnva's Avatar
bullardnva
Cool fuel help
i just bought my first mustang. 1999 v8 4.6 GT. i got a great deal cause it wont start, it turns over very good , when i turn the key on i cant here the fuel pump running. is there a way to add gas some were on engine so i can see if it starts?
Old Aug 20, 2021 | 07:09 AM
Brewster Rooster's Avatar
Brewster Rooster
Have you scanned it for codes? You can rent a scanner from Autozone. That would be the first step. The results from that would be the next step...when I buy none running cars I usually squirt a little starting fluid in the intake to see if it fires even for a second...
Old Aug 20, 2021 | 04:33 PM
imp's Avatar
imp
No pump running sound: Check fuse feeding the pump. Check the Inertial Fuel Shut-off Switch for being tripped. Check that PCM (computer) Power Relay is energizing. Try replacing Fuel Pump Relay with another relay.
If dead-ended, run two wires to fuel pump from battery, see if pump runs when supplied 12 volt power. You can spray a bit of Starting Fluid directly into the air intake at the air filter; if engine fires, runs a second or two, ignition is functioning.
ddub07
Nov 8, 2017 11:33 AM
4.o stang
Nov 28, 2016 06:19 PM
mustang565
Oct 27, 2009 03:16 PM
Phalanx8
Mar 23, 2007 11:01 PM
Cornbread
Nov 28, 2006 03:50 AM
