Fun FORD Weekend at Epping ( NEDW)
My car just hit the final nail in the coffin for Fun Ford weekend.
Guess when we were doing the starter/clutch cable last night a wrench or something hit the radiator.
Got an indent and a leak just below my overflow can thing.
SO
Now I need me a new radiator
Oh and only 403 miles to go!
SO
Welp I might as well shoot for an Aluminum.
So I'm gonna go for an Aluminum 2 row radiator.
They run anywhere from 170-500 bux....
Just need to know the dimensions of the stock 2 row in my fox.
Well, OB. If anything can go wrong it will, and in youre case it did. lol. If it aint one thing its a motherf*cking nother. So, you have to buy a Radiator AND a water pump. lol. you might as well go with those COOL blue hoses. lol. You cant be leaking anything either. And you still hae alot of miles to prduce. lol. Im not sure you will make it to FFW.
Rmembr, you need help CALL!!
OB, I got the Ford Racing Radiator from Summit in my '88 and it fits fine. I had to replace my stock one when I let one of my tie down straps get too close to the drain **** and I went a little fast on the right hand turn into the strip and the car moved over and the strap partially tore the drain **** out of the radiator! I go to open the hood and antifeeze is dripping on my shoes! Boy was that a ****ty day, tow all the way to the track and turn right around and come home to spend more money for something I screwed up.[:@]
(see, now didn't that tale cheer you up some!
) true story, I swear!
summit part # FMS-M8005C for $247.88. you do have to modify the top radiator hold down brackets just a bit, but the Ford Racing catalog says you can call the tech line for a fax copy of the instruction sheet.
) true story, I swear!summit part # FMS-M8005C for $247.88. you do have to modify the top radiator hold down brackets just a bit, but the Ford Racing catalog says you can call the tech line for a fax copy of the instruction sheet.
Empty, i didnt see you there. Roundman, today sucked. I actually arrived just as OB pulled in and we didnt plan it. lol. We walked around for 30 minutes and no one was there, it rained and it sucked. Last 2 years were much better. Tmrw is suppsed to me much better. OB has to work though. lol.
