Pipes, Boost & Juice Talk about Exhaust, Nitrous, Blowers, Turbos, Superchargers... whatever makes you go faster!
Injector question
Old Mar 31, 2006 | 08:10 PM
redmustang83596's Avatar
redmustang83596
Default Injector question
i just read the tech article about calculating my injector size, but it never mentions anything about nitrous... what should i do if i am adding nitrous in the mix every once in a while... its a 250 shot, and yes my motor can handle it so i dont wanna hear anything about blowing the motor...
Old Apr 1, 2006 | 08:35 PM
FullAuto's Avatar
FullAuto
Default RE: Injector question
If it's a 250 shot, I'm betting it's a wet kit. If it is a wet kit, then there is no need to use a larger injector because the kit will add the extra required fuel. If you were running a dry kit, the injectors would add the extra fuel so you'd need injectors large enough to support the power of the motor and nitrous combined. But at 250hp, you aren't running a dry kit.
4cylinderplus2
Oct 9, 2020 07:45 PM
Dathan
Oct 5, 2015 05:52 AM
treesloth
Sep 28, 2015 07:03 AM
MacSerio
Sep 27, 2015 01:05 PM
