Turbo Or S/C
Here soon, i will be adding one of these. Whatever i do, i will only have it to about 4-6psi to bein with since i will have a stock engine. As i mod the engine, i will want to boost up the PSI for more power. I was looking at the Whipple S/C and Turbo setup. I was wondering which of these would make better power when fully used. In the end, i want to max out the S/C or Turbo once i forge the engine.
-W |
RE: Turbo Or S/C
to "max out" a sc or turbo youll need a new block to handle it. and its not a good idea to run anything at its max output. just below is better. id go turbo personally. less paracitic hp loss
RE: Turbo Or S/C
personally i'd go with the turbo. but before i thought to do that i'd build the bottom end first them put in the turbo so your not limited to 9 psi with a stock block
RE: Turbo Or S/C
Ok well i dont mean MAXXXXXXX out but i wanted to know what offered me more PSI potential after i redo the engine. I have a 06 GT btw if that helps.
-W |
RE: Turbo Or S/C
Another vote for the Turbizzle.
RE: Turbo Or S/C
Yea the more and more i see things on the net and read posts, the more i think the turbo is the way to go. Also... I heard a while ago, like 6 years when i younger before i really knew what exactly a turbo was and how it works, that they go out after time and you have to replace them. Any truth to this?
-W |
RE: Turbo Or S/C
nothing lasts forever. turbos i dont think wear out any faster then a sc would
RE: Turbo Or S/C
YOU CAN RUN MORE THAN 6LBS ON A STOCK BOTTOM END.... YOU CAN RUN UP TO 15LBS WITH EASE.... IT'S ALL IN THE TUNE.....
Turbos last a long time, they will probably out last the car... I don't know who you heard that from but they are wrong... |
RE: Turbo Or S/C
not like you're really gonna do it, but turbo is the overall best. i wouldn't do it unless you build your engine to really pump some power out. if you're only "planning" on running like 6psi, just get a supercharger and save yourself a few grand.
RE: Turbo Or S/C
I was only talking about running 6psi or so when i first install either the S/C or the Turbo. Then, after i take care of the other things, suspension, cluch, rear end, etc, i want to get forged insides and then boost either the S/C or the turbo up to what it's really able to do. I dont plan on getting another short block or anything so stock block with forged insides, whatever that PSI will handle with a proper tune, i just wanted to know what made better power when i want to go bigger then just 6psi. Not really more RWHP but all around power curve.
I have decided it's either a whipple S/C or a Single Turbo (no need for a double correct if i not going to be like completely redoing the whole engine?) -W |
