ok i just bought a 351 block, stock ford 95 truck block, and a 408 kit from eagle, i plan to run 8.5 cr with the stroker 8-10 lbs of boost from a new s-trim, as for the motor i have trick flow upper and lower for the 351w, fully ported twisted wedge heads ,1.6 trick flow rockers,ford racing f-303 cam, ( will get a custom grind later ) what kind of hp could i expect with this combo???? thanks in advance
