Pipes, Boost & Juice Talk about Exhaust, Nitrous, Blowers, Turbos, Superchargers... whatever makes you go faster!
Nitrous
Old Apr 24, 2006 | 06:56 PM
Mustangkiler's Avatar
Mustangkiler
Default Nitrous
How easy is it to install a nitrous system a 100 to 125 with 10 lb bottle on a 94 gt that injects it in the intake tube?and should i get the zex kit which is tps activated or the nos one that has a separate switch for it. Just want to make sure i get the easier one to install and how dificult it is?Do i need dual stage system?Its a stock engine.
Old Apr 24, 2006 | 08:27 PM
redfireshaker06's Avatar
redfireshaker06
Default RE: Nitrous
Just get an NX Wet Ford EFI kit. Its not hard to install
Old Apr 24, 2006 | 10:37 PM
COMPMACH's Avatar
COMPMACH
Default RE: Nitrous
I just bought the nos stage 1 kit from summit for my 95 gt.Its looks to be fairly easy to install,but i'm sure theres other kits out there that may be much easier to install.I hope to have my kit on in the next couple of weeks.
Old Apr 24, 2006 | 11:28 PM
nitrous_bob's Avatar
nitrous_bob
Default RE: Nitrous
i have had both. the zex is a bit easier for the fact that the selonoids and reg are already together.
if the nos 5115 dry kit took you 3 hours ( should be typical for the first time) the zex might be 2 1/2
i had no issues w/ the zex...but i chose nos for my 3rd kit. no real reason why...i felt better about it.
the zex kit doesn't tell you what the black reset button does..anywhere in the directions or the website.
or what the flashing lights mean...i just don't like incomplete stuff.
all in all...both very ez installs, i do prefer the tps activation over the microswitch, but check out a new summit...msd has a new multi-switch that will activate anything w/ 3 or 4 different components...tps being 1 of them.
Old Apr 25, 2006 | 12:37 AM
WLingle92lx's Avatar
WLingle92lx
Default RE: Nitrous
NX ALL THE WAY! I have one and I love it
I gained 30 more rwhp going from a zex 150 dry shot to an NX 150 wet shot.
The ZEX Wet kit is a very good system. Never had one but I heard good things about them.
BTW Wet kits hit way harder than a dry kit. Stick to a dry shot shot for smaller shots 100-125.
If you get a dry kit than you'll need to put a bigger fuel pump in if you go 125+
Old Apr 26, 2006 | 08:48 PM
Mustangkiler
Default RE: Nitrous
Can i run a 100 shot without adding a fuel pump?and not worry about the pistons?
Old Apr 26, 2006 | 08:57 PM
WLingle92lx
Default RE: Nitrous
You can run 100 shot with the stock fuel pump. I ran a 125 ZEX dry on my 5.0 with the stock 88lph fuel pump and stock 19lb injectorswith no problem. Im not sure what size fuel pump is in your car.
If your car has hyperutectic pistons than i wouldn't go over a 100.
Sandmanbjj
Aug 21, 2015 12:38 PM
mstngdvr17
Dec 25, 2003 04:55 PM
jhogan2424
Nov 5, 2003 08:51 PM
67gt500
Aug 17, 2003 04:01 AM
