what will i need with nitrous???
i got an 89 5.0 with a few bolt on mods. i'm getting between a 50-100 shot of nitrous. what else will i need. one of my friends told me that i should check to see if i needed a new fuel pump b/c if the fuel pump can't support the nitrous when its intruced into the engine, the engine will be mostly running off the nitrous, inturn blow up the engine. what else will i need (fuel pump, lines, rails)?? or is a 50 shot small enough where i can maniage stock parts?
Thought you guys would know best thanks
well you car shouldnt realy have problems but it is a little old, i personally(OPINION ONLY) would change the pistons or something. and upgrade the fuel system you would not have to worry about anything
