Pipes, Boost & Juice Talk about Exhaust, Nitrous, Blowers, Turbos, Superchargers... whatever makes you go faster!
accessories belt not working????????
Old Jun 8, 2006 | 02:12 AM
93BlackSunshine's Avatar
93BlackSunshine
Default accessories belt not working????????
Ok we have the v1sc-trim vortech on a 92 5.0 with a/c delete, and the belt tension is not right. If we put a smaller belt on we can't get it on the pulley, but if we put a slightly larger belt on and barely fits over the pulley once it goes on the belt is to loose( the belt rubbs underneath the tensioner)..It just seems that there is something not right. Have any of you ran into this, or do i just not make sence.. because i am just very frusrated with this piece of $hit!!!!!!!!![:@]
Old Jun 9, 2006 | 02:10 AM
WizardBlack's Avatar
WizardBlack
Default RE: accessories belt not working????????
Get a March Alternator Tensioner setup.
Mark
Old Jun 9, 2006 | 11:27 PM
luckythirteen13's Avatar
luckythirteen13
with the march a/c delete, the ps pump is not high enough for the normal way of routing the belt. you can try getting the ford a/c delete that will move the ps pump higher up so that its in the same location as the a/c compressor used to be. the march kit you have has the ps pump only sligtly higher then stock right?
mungodrums
Oct 7, 2015 04:01 AM
Pyrate Dave
Sep 10, 2015 07:30 PM
Boostaddict
Lethal Performance
Sep 8, 2015 09:56 PM
cbird1177711
Sep 3, 2015 08:43 PM
Sep 1, 2015 08:16 PM
