BBK H pipe Install Problems.. Help
I have the ford dealer installing BBK shorty headers with BBK H pipe without cats, and they are having a time with it getting to fit, even with ford racing cross member. Any thoughts would be appreciated.
is it brand new? if it is, are the mechanics stoned when they are working on it?
if it's used, they may need to separate the h-pipe where it welds together at the "H" crossbeam other than that...there are no probs to run into, hardest part is getting the old stuff off.
Yes Brand New. It seems as if the highhump of the cross over should be on the drivers side,but the mechanic said that the holes to mount transmission to cross member won't line up if it was used that way.
try to losen up your catback and allt he other bolts and when you get it all lined up bolt it up. i guess i had a good bbk h pipe because everyone else seems to hate them. but i also put my whole system on at once soo everything was brande new and i lined everything up and then bolted it. it was a breeze
