Pipes, Boost & Juice Talk about Exhaust, Nitrous, Blowers, Turbos, Superchargers... whatever makes you go faster!
PLUG QUESTION???
Old Jun 17, 2006 | 12:54 PM
kl92gt's Avatar
kl92gt
Default PLUG QUESTION???
Alright i install a nx wet kit about a month ago and i just put a 50 shot in it just to get used to it on stock plugs and didnt need to retard timing. but today i plan on putting the 100 jets in i was wondering if i would need a colder plug and if so which one? also im goin to retard the timing 2 degrees should that be enough?
Old Jun 17, 2006 | 01:07 PM
kl92gt's Avatar
kl92gt
Default RE: PLUG QUESTION???
i have autolite 25 in it now
Old Jun 17, 2006 | 04:45 PM
JD1969's Avatar
JD1969
Pro. B.S. caller outer
I like the NGK TR6 plugs, I would put them in just to be on the safe side even though some will say it's not 100% needed on just a 100 shot. They are fine to daily drive on as well.
Old Jun 17, 2006 | 05:49 PM
kl92gt's Avatar
kl92gt
thanks ill be getting some tommarrow and uping the shot
Old Jun 17, 2006 | 05:57 PM
nitrous_bob's Avatar
nitrous_bob
yeah you can never be too safe, but personally i use stock plugs on 100 shot, gapped at .040" and if it's cool run 14* initial timing on 93 octane
so, if your 100% sure you didn't lean out on the 50, 2* is fine, but if you never read your plugs after a nitrous run, or it was cooler out than now (considerably different like 20*)
might wanna back off 4*
14* timing is a little cutting edge, not really worth the risk unless your certain your out of danger.
only way to tell is by mph at the track, or reading your plugs
Old Jun 17, 2006 | 07:33 PM
kl92gt's Avatar
kl92gt
i just did a run on the 50 shot just to check the plugs they look good so im going to back timing down 2-4 degrees and get new plugs andgap them at .040 then try it out and check the plugs ill let you all know how it goes tomarrow but thanks a lot
Old Jun 18, 2006 | 03:14 AM
nitrous_bob
cool, you don't always hear sparkknock, but it will show on the plugs.
and you will melt a plug b4 burning a piston, but not a lot of time in between if you get super lean on the spray.
Granatelli Sales
Mar 25, 2016 08:01 PM
2007StangV6
Jan 28, 2016 06:09 PM
Granatelli Sales
Dec 27, 2015 06:28 PM
cbird1177711
Sep 2, 2015 04:12 PM
