Pipes, Boost & Juice Talk about Exhaust, Nitrous, Blowers, Turbos, Superchargers... whatever makes you go faster!
how ot fix x pipe
Old May 3, 2004 | 06:45 PM
kevin02's Avatar
kevin02
Default how ot fix x pipe
hey everyone, i put a x pipe on my 04 mach and it leaks on the driver side, yes the gasket aand everything is on, and ive even taken it off a few times and tightened it but i cant seem to get that last little annoying leak out of it. can anyone help? 1 other question is, when i first bought the car i could chirp pretty good into 3rd, but since i put my x on i cnt do it anymore. do you think it has something to do with the little exhaust leak? if not then why would it have stopped chirping? thanks everyone.
Old May 3, 2004 | 07:40 PM
callmecobra's Avatar
callmecobra
Default RE: how ot fix x pipe
is it leaking from the gasket? and what size x pipe is it?
Old May 3, 2004 | 07:57 PM
kevin02's Avatar
kevin02
ITS LEAKING FROM WHERE IT CONNECTS UP NEAR THE MOTOR, S FAR AS SIZE, IM GUESSING THE SAME SIZE AS THE STOCK EXHAUST, IT HAS NO CATS, DONT KNOW IF THAT HELPS U ANY
Old May 3, 2004 | 08:00 PM
callmecobra
no cats help....but im wondering if you put to big of a pipe on...that would result in HP loss
Old May 3, 2004 | 08:11 PM
kevin02's Avatar
kevin02
so what can i do about the power loss? do i need a bigger cat back or need headdrs or both?
Old May 3, 2004 | 08:27 PM
callmecobra
im not convinced you lost power...what kind of cat back do you have? long tube headers, get them
Old May 3, 2004 | 08:38 PM
kevin02's Avatar
kevin02
i just have evrything stock, so i would need to get a catback, im really debting between the magna packs, magnaflow cat back, and slp loudmouth
Old May 3, 2004 | 08:42 PM
callmecobra
magnapack would be best with your x pipe
Old May 3, 2004 | 08:45 PM
kevin02's Avatar
kevin02
would that also sound good with lt's? where the hell can i find magna's ive looked alot of places
Old May 3, 2004 | 08:51 PM
callmecobra
www.ninosport.com long tubes with off road pipe and magnapacks would sound absolutely SICK
