an intercooler is going to cut off about 2psi. so if you have an 8 pound pulley, you're only going to get about 5-6. get a smaller pulley.
I'm intercooled and make just barely over 8 on my boost gauge near redline. Does that mean I might have a 10 psi pulley? That might explain why I make a little more to the wheels than others running 8 psi.
Does anyone know the dimension of the 8 psi ProCharger pulley?
ORIGINAL: chaplainracer
Mods are limited to Longtubes, o/r X pipe, and cat back.
Any mod that lowers the air restriction into and out of the motor will cause lower boost readings, long tube headers are a big help in that department. Therefore you will see a lower boost reading. If you have a true 8lb pulley and nothing else is wrong, your s/c is forcing the same amount of air into your engine as it would on a completely stock car at 8psi because boost is only a measure of restriction not airflow.
