Pipes, Boost & Juice Talk about Exhaust, Nitrous, Blowers, Turbos, Superchargers... whatever makes you go faster!
zex nitrous install help!!!
Old Jul 15, 2006 | 03:31 AM
TRIGGERFTL's Avatar
TRIGGERFTL
Default zex nitrous install help!!!
Ok I have looked all over the net and have not found 1 tutorial on the Zex Dry kit install for 199-2004 4.6 mustangs. I know how to hook this system up because I have it in my 98 supra but I need to know what color the tps wire is that we use and where is the tps on this car. I am also running a air/fuel gauge and need to know which wire on the o2 sensor to tap into thanks in advance. If anyone has pics of there setup with Zex please post thanks.
Old Jul 15, 2006 | 04:08 AM
ShadowDrake's Avatar
ShadowDrake
Default RE: zex nitrous install help!!!
I've got this one... calling dibs Let me go look for an engine bay picture.
Edit: Here we go... got a nice picture from my stang. The TPS has a red box around it. Unplug the connection there. Remove some of the plastic covering the wires, and put the little connector on the middle wire. You can see mine in the picture if you look close. After you've tapped the wire, plug it back in and you should be good to go. Follow Zex's instructions to set and test it before you try starting the stang or running nitrous through the lines.
Looking on the A/F now. What brand is your A/F meter, Autometer?
Edit 2: Forgot to attach picture, whoops.
[IMG]local://upfiles/20167/AA39FA3116934D7CB2BEB64C8E204EF0.jpg[/IMG]
Edit 3: Here is what autometer says to tap. Should be universal for all A/F ratio gauges but you may want to check:
Air/Fuel Ratio – Oxygen Sensor Gauge Installation
for 4.6 engine(s)
Pin # 60 at PCM which is a gray wire with a light blue stripe or pin # 87 which is a red wire with a black stripe. Either will work.
mtgldr
Feb 3, 2024 09:00 PM
BOBCATJACK
Sep 14, 2015 02:18 AM
Sep 10, 2015 08:39 PM
