Pipes, Boost & Juice Talk about Exhaust, Nitrous, Blowers, Turbos, Superchargers... whatever makes you go faster!
[Deleted]
Old May 17, 2004 | 04:18 PM
Deleted User's Avatar
Deleted User
I ♥ Acer
Default [Deleted]
[Deleted by Admins]
Old May 17, 2004 | 04:43 PM
SilverGTV8's Avatar
SilverGTV8
Default RE: Installation of x-pipe
Well you need some pentrating lube, 21" extension for 1/2 drive, 1/2 drive rachet, 14mm or 15mm (can't remember) six point deep socket 1/2 drive 1/2drive swivel (only really need this for one nut). Get the car up high enough to get the socket and drive on it and break it free. It will take some mucsle that is why you need the 1/2 drive. You might break one so be prepared to get another one from Ford or pick some up in case.
You may need to heat the bolts to.
There is only on gasket and it is on the passenger side flange kinda shaped like an oblong "O" make sure you take it off the manifold or out of the old h-pipe, if it is damaged you will need to replace it. Have to get it from Ford and my dealership didn't even know that there was a gasket there. Luckliy I didn't wreck the one that was there. So I didn't need a new one.
But yes it can be done in your drive way if you have the tools.
Old May 17, 2004 | 05:04 PM
VertStangGT86's Avatar
VertStangGT86
Is the flange on the new ones on that side different or something? Why would you need a gasket and why would there only be one of them not two or more?
Old May 17, 2004 | 05:51 PM
SilverGTV8's Avatar
SilverGTV8
Never put one on an Fox body, but on the new GT's the passenger side needs a gasket, it's not paper but a soft steel and mesh gasket. It sits inside a groove in the flange of the x/h pipe and clamps to the manifold. Not sure why, the rest of the system is a gasket less system (ball and cup joints). They must have problems sealing on that side.
Old May 18, 2004 | 02:28 AM
VertStangGT86
Weird, probably a post production fix, maybe something didn't sit quite right and they had to add them.
Old May 18, 2004 | 07:43 PM
RedStangGT2000's Avatar
RedStangGT2000
How long of a job is it???
Old May 18, 2004 | 08:31 PM
SilverGTV8's Avatar
SilverGTV8
Took me and a friend 3 hours to change my h-pipe to the x-pipe and put on a catback system. The longest part was trying to figure out how to get the passenger side exhast tube over the axle without taking the suspension apart. If I had to do it again 2hrs start to finish.
To just change the x-pipe it should take about 45mins for someone inexpericnced but good with tools.
Boostaddict
Lethal Performance
Oct 1, 2015 08:58 AM
Boostaddict
3.7L V6 S550 Tech 2015 - 2017
Oct 1, 2015 08:57 AM
DtRockstar1
Mustang Videos
Sep 27, 2015 07:46 PM
Camster
Sep 10, 2015 11:18 AM
