BLOW OFF VALVE
i am about to install my BOV on my s/c-ed engine. i had to buy a Blow Thru MAF from PMAS for about 225 bucks but with the procharger setup it might already be blow thru, but im not sure. pretty much in order to put a BOV on a s/c setup the blower has to be a centrifugal, and you have to convert to blow thru, which i have learned by asking 1000 questions on this board, thanx everyone.
if your setup is like mine (check my bov conversion post) you can do a similar setup as mine. as for the mas, just get an adaptor to make it blow through, adaptors are like 30$ or you can make your own, oh and you gotta recalibrate it im told[&:]
ORIGINAL: catchds
so how do you do it do u just replace the by pass valve with a blow off valve because i tried to do that but nothing happened
ORIGINAL: catchds
Is your MAF sensory before or after the BOV/BPV?
bradleyb
Nov 27, 2015 07:50 PM
