Pipes, Boost & Juice Talk about Exhaust, Nitrous, Blowers, Turbos, Superchargers... whatever makes you go faster!
do you know
Old Aug 11, 2006 | 11:38 PM
WRENCH HEAD's Avatar
WRENCH HEAD
Default do you know
I HAVE 91 LX 5 SPEED 5.0 WITH 10,000 ON NEW MOTOR.ANYWAY I JUST BOUGHT THE PROCHARGER P1S WITH THE 12 RIB BELT. MOTOR HAS A B CAM IN IT BUT EVERYTHING ELSE IS STOCK. ANY WAY WHAT SIZE INJAECTORS ,MAF AND SENSOR SHOULD I GET. WHAT ABOUT A FUEL PUMP OR IGNTION.I'AM GONE TO GET THE TRICK FLOW HEADS AND MANIFOLDS WHEN THE FUND ARE REBUILT. OH YEAH HOW ABOUT A FMU THANKS
Old Aug 12, 2006 | 01:36 PM
FullAuto's Avatar
FullAuto
Default RE: do you know
Depending on how much power you plan on making, I'd probably recommend 42lb injectors and an 80mm PMAS MAF. I'm not guessing you'll be making more power than this because most aftermarket block people aren't asking these types of questions. For a fuel system, I'd run a 255lph intank and a 255lph inline if you're keeping the stock fuel lines. Buy Walbro pumps. Walbro makes most of the pumps for other brands to rebox. So don't pay extra for a BBK or something because when you take it out, it will say Walbro on it. If you ever plan on running larger braided lines, go with a Weldon pump. If you buy enough injector, you won't need a band-aid FMU. Just as if you buy enough pump(s), you won't need band-aid Boost-A-Pump.
BTW, turn off the caps lock.
Old Aug 12, 2006 | 04:27 PM
MadMan@TheWheel's Avatar
MadMan@TheWheel
You can if you want make a projection about expected HP and divide by 16. This will give you a close estimate for injector size. It is not of course EXACT, but better than guessing.
Old Aug 12, 2006 | 04:34 PM
JD1969's Avatar
JD1969
Pro. B.S. caller outer
ORIGINAL: WRENCH HEAD
Please don't type in all caps, not only does it make your post very very hard to read but it is considered yelling on a web forum.
Thanks
JD
