Pipes, Boost & Juice Talk about Exhaust, Nitrous, Blowers, Turbos, Superchargers... whatever makes you go faster!
Saleen supercharger max power?
Old Sep 5, 2006 | 01:03 AM
Thumper33's Avatar
Thumper33
Default Saleen supercharger max power?
I've seen a lot of good stuff about how efficient the saleen supercharger is. People seem to say that if you're not going to go crazy with the boost that I'll be very happy with the saleen. What I haven't seen is how much power are people able to get out of a saleen supercharger? Are you not supposed to run any more boost than what their upgrade kit gives you? It says 475 horses for this kit, but can you go to a smaller pulley again and run even more boost? I'm just wondering why you never see 600 hp cars with the saleen supercharger.
Old Sep 5, 2006 | 10:55 AM
QuickShortBus's Avatar
QuickShortBus
I ♥ Acer
Default RE: Saleen supercharger max power?
Because they aren't efficent enouugh to feed 600hp without creating a huge amount of heat.
Old Sep 5, 2006 | 03:04 PM
Thumper33's Avatar
Thumper33
But the kenny bell can put out that kind of power right? I thought the saleen was supposed to be more efficient than the kb.
Mike
Old Sep 5, 2006 | 03:40 PM
QuickShortBus
I ♥ Acer
According to someone on here it is, but I have yet to see results to prove that. There are several KB models that can easily support 600+whp.
Old Sep 5, 2006 | 03:50 PM
tripsevn7's Avatar
tripsevn7
Moderating with Angels
the saleen blower is a whipple based blower, i would believe w/ the design utilized that if 1 had forged guts, you could easily hit the 600 mark. much like kevin stated though, i havent seen anyone do it with the saleen blower yet.
Old Sep 5, 2006 | 04:07 PM
QuickShortBus
I ♥ Acer
The biggest problem with the Saleen is the small intercooler that cannot keep up with high boost levels. Yes it has twin intercoolers but they are very small and KSS3V on here has already said that he started to loose HP at 16psi with his Saleen s/c.
Old Sep 5, 2006 | 04:20 PM
Birdieman4's Avatar
Birdieman4
The Saleen blower is capable of around 23-24 lbs of boost. I would say that you are not sacrificing that much efficiency until it is spun making around 17-18 psi. If you had a forged internal stang, properly tuned and set up, I would say that at 18 psi the car will be making around 650-700 rwhp. And it would not be that inefficient doing it.
Old Sep 5, 2006 | 06:49 PM
Thumper33's Avatar
Thumper33
So now I guess i'm confused. If the kenny bell has bigger intercoolers, then wouldn't it be more efficient at lower pressures as well? Am I wrong that the saleen is supposed to be among the most efficient at lower levels? Perhaps it's that the saleen is more efficient, but just doesn't have a large enough intercooler to support the higher boost levels????
Old Sep 5, 2006 | 08:44 PM
Thumper33's Avatar
Thumper33
Maybe I've figured out the issue here... is there actual data on supercharger efficiency? I'm just trying to figure out the most efficient configuration for making about 500 rwhp. I just wanna beat stock C6s on pump gas, w/o sacrificing too much fuel efficientcy or streetability.
Old Sep 5, 2006 | 08:49 PM
QuickShortBus
I ♥ Acer
ORIGINAL: Birdieman4
I think you have forgotten everything that was disscussed here: https://mustangforums.com/m_1511841/tm.htm Obviously you have convienently forgotten this conversation with KSS and their car falling flat on it's face and LOSING hp at 16psi due to ACTs being so high even with a LARGE intercooler resevoir. Unless you can provide proof that the Saleen s/c stays efficient at the boost you claim then I don't see why anyone would believe what you are saying, Tim maxed the blower out and he wasn't anywhere near 23psi.
