kb foxes....?
Actually, this is what I like about the screws!
I'm used to larger displacement motors and the 4.6 just didn't seem to much torque at low rpms. Now it's not a problem.
ORIGINAL: FoxGT
I'm talking about performance, not what is best at breaking the tires loose in 3rd gear at 2000rpm as soon as you punch it.
ORIGINAL: mnile9127
When I say this I am talking about perfomance. What would happen when
those tires grab at 2000 rpm in 3rd gear at full rated boost? I'll would tell you
but you will probably want to see some article clips, statistics, specs, or
some other BS. I was fortunate to be able to drive my friends cars.
No, they weren't same, but the there wasn't that much difference.
Example:
1995 GT KB Mild cam 8psi street/12 psi strip
1996 GT Procharger Intercooled 14psi street/20 psi strip
1992 Notch 408 250 shot
2003 Cobra Eaton 75 shot
1987 Grand National Turbo 23 psi
1992 LX 306 Turbo 10 psi
There are more of my friends cars, that I have driven.
I'm only comparing the power adder, I would prefer everyone of those
cars have the turbo, but if not twin screw all the way.
Example:
I just don't understand why you keep saying the kb is the most efficient supercharger. You keep saying it, but you don't show any proof of it. All you can tell me is, "I would rather have a twin-screw over the others" I don't care which car you prefer, I don't care what type anyone prefers. I'm stating facts & you have yet to try to put up a good fight on my main point. This whole thing started over you calling the kb the most efficient. I called bullsh*t. You have yet to show me anything backing up what you're saying, instead you keep telling me which one you like & that you take it anyday over the other superchargers.
ORIGINAL: Justastockmustang
ORIGINAL: FoxGT
The best? What makes it the best? The all rpm powerband? Centrifugals are more efficient on high end, so what makes them the best for a person that wants the most power he can get on high end? & for someone that wants to pull stumps... the roots is a more efficient unit for down low power.
A good all around supercharger? hell yes. The best? That depends on what you want.
IMO If you're going to spend 2000-4000 you most likely would want all rpm power.
Now if you can tell me you wouldn't like to have all around power for that kind
of money then I say you're F***ing crazy. If you're scared of all out power then
I think you need to be driving a KIA SEPHIA or something, IMO. Like
I said before EFFICIENCY isn't the dissagreement PERFORMANCE of the
power adder is. Based on my experience and what I like, I say
Turbos are the Best Power Adder, Twin Screws are the Best Supercharger
If you you're ever in the Chicago Area, I can SHOW YOU why I say this.
ORIGINAL: mnile9127
This is where the disagreement started.
Same pinning you into your seat experience for the driver just not nearly as much because you know what's coming before it comes.
ORIGINAL: mnile9127
The KB manifold can be custom made to fit whatever lower intake
you already have. The unit bolts directly onto that lower intake.
Tell KB to send the Discharge Manifold uncut. Then have it custom cut
to fit your aftermarket lower intake. I didnt give bad info. I wasnt
specific as to what I was saying. As far as an intercooler for the 5.0
pushrod motors, that also takes a little fab work. Heres a pic:
[IMG]local://upfiles/24375/17C175B45C074A99964852CC481D9E91.jpg[/IMG]
[IMG]local://upfiles/24375/7B513F4FEC1841F6BD463202AFF56A76.jpg[/IMG]
ORIGINAL: mnile9127
ORIGINAL: mnile9127
The only power adder that is more efficient than a twin screw on high end
is a TURBOCHARGER! I will change my statement and say:
The Best Supercharger is a Twin Screw, but the Best Power Adder
is a Turbo.
is a Turbo.
Well, I hope your project goes well. I'm in the process a build also.
331 Dart Sportman Block using my KB 2200 at 15 psi. I'm
gunning for 700RWHP. Once my new motor is put together.
I'm going to turn up the boost on the existing (12-14psi) and see how
much the stock block will take.
