Pipes, Boost & Juice Talk about Exhaust, Nitrous, Blowers, Turbos, Superchargers... whatever makes you go faster!
how much boost will be gained??
Old Oct 3, 2006 | 03:46 AM
99roushgt's Avatar
99roushgt
Default how much boost will be gained??
if i drop down from 3.60 to a 3.00 or 2.90 how much boost would be gained?? i was seeing 10psi on my gauge before non-itercooled i am now intercooling it so i know it will loose a lb or so but im just curious if i will see my goal of a minimum of 15-17psi with a 3.00 or a 2.90????
Old Oct 4, 2006 | 01:16 AM
99roushgt's Avatar
99roushgt
Default RE: how much boost will be gained??
wow
Old Oct 4, 2006 | 01:44 AM
blackbetty01's Avatar
blackbetty01
Its hard to guess since it varies so much. I have a vortech SQ trim S/C with a 3.6 and I make 10psi. My buddy runs an intercooled Procharger and he makes 15-16psi with a 2.8
I would look into a Reichard Non-Slip pulley if you go that small.
Hope that helps
Old Oct 4, 2006 | 02:09 AM
jpmustanggt's Avatar
jpmustanggt
Is the 3.6 pulley the stock pulley?
Old Oct 4, 2006 | 03:07 AM
luckythirteen13's Avatar
luckythirteen13
rule of thumb is 2psi per pulley size. each size down gets you about 2ps of boost. unfortunately each step down isnt always the same. from a 3.6 to a 3.0 you should see about 5psi, maybe 6psi. the 2.9 is so close to 3" that its worth about 1psi more then the 3.0" would be.
Old Oct 4, 2006 | 03:11 AM
99roushgt's Avatar
99roushgt
so since im going to loose a lb or so cuz of the intercooler i should go with the 2.90 then and i should get the 15-17psi?? i will use the rr ultra grip pulley and hopefully get no belt slip the pulley and belt are the last things needed to complete my project
Old Oct 4, 2006 | 02:03 PM
LvGordo's Avatar
LvGordo
ORIGINAL: 99roushgt
call vortech, they could probably answer your questions better than it seems you may be getting here.
Old Oct 4, 2006 | 08:44 PM
99roushgt's Avatar
99roushgt
i did and the guy acted like he was choking on a sweaty nut sack and had no clue i think he thought i was speaking arabic or something those guys are puds at vortech and unless your buying something they dont like to be very helpful.
Old Oct 4, 2006 | 10:18 PM
blackbetty01
ORIGINAL: jpmustanggt
Yes
Do you have forged internals? Or are you going to be pushing 15psi with an intercooler and a Snow meth kit? That seems pretty dangerous to me. If you are interested in getting rid of the Snow Meth kit send me a PM.
Old Oct 5, 2006 | 03:43 AM
99roushgt's Avatar
99roushgt
yup new bottom end is forged and the meth kit is anyones who wants it but blackbetty has first dibs
