Pipes, Boost & Juice Talk about Exhaust, Nitrous, Blowers, Turbos, Superchargers... whatever makes you go faster!
blow off valve??
Old Oct 15, 2006 | 09:13 PM
kev2369's Avatar
kev2369
Default blow off valve??
I have a 94 GT with a Procharger set up. It was on the car when I bought it so we are unsure of how everything is supposed to be hooked up. There is a blow off valve inbetween the charger and the intercooler, there is places on the bottom for vacuum lines to go but they have been blocked off with screws....we are unsure of where to run them to....
any ideas? If any one has some pics it would be greatly appreciated
thanks, kev
Old Oct 16, 2006 | 01:19 AM
FoxGT's Avatar
FoxGT
Default RE: blow off valve??
I'm confused as to what you're asking? If you're asking where the line from the bov goes, it plugs into the intake manifold or somewhere AFTER the throttle body to where the line is under vacuum at idle. The 5.0 should already have some vacuum lines running from the bottom of the upper intake (if stock) you can just use a T fitting & run a line off of one of those.
Old Oct 24, 2006 | 11:50 AM
92whitelightning's Avatar
92whitelightning
just like he said....on most bypass valves there are 2 vacuum line nipples a "top one and a bottom one" and u run the top one....the closest to the hardener screw....to the back of the upper intake manifold and leave the bottom one open...use shouldnt have anything plug in order for proper function
GimpyHSHS
19
Dec 19, 2023 01:12 PM
mrtrodonet
Sep 19, 2020 03:12 PM
bradleyb
Nov 27, 2015 07:50 PM
bradleyb
California Regional Chapter
Oct 1, 2015 01:02 AM
Sixer4Life
Sep 29, 2015 07:03 PM
