Problems with getting an intake........
I have a 2005 mustang GT and just got the California Dream body kit for it. I want to make the hood a funtional ram air but im having second thoughts about doing it. And the reason is for hydrolock. Do CAI's have a high tendency to sustain hydrolock? i just ordered a K&N intake and had some guy tell me to be carfeul around puddles, am i seriously gonna have to slow to 5mph everytime i see water? and with a funnel scooping anything that gets near my hood and puting it in top of my CAI, is that a bad idea? are there any tricks out there that You guys use to prevent hydrolock when it rains (i.e certain types of intakes, tricks)? i figure i could stick a towel or make a custom block for the scoops. Or just forget about it. is it worth the trouble? please help my dumb ***. i need it!
Here is the typical response you will get from shaker conversion vendors :
" Q: Is water or inclement weather driving a concern with the ‘05+ Shaker?
A: No. The system was designed with water management as a top priority. The Engine cover includes four drain holes with attached high-temp rubber tubing to direct water away from the engine. Further, water escape holes have been designed in the ductwork, allowing any water to escape prior to reaching the factory air box. If water does make it to the air box it will drain out the bottom."
Hope that helps.
E.
Hope that helps.
E.
Seanam
Oct 4, 2015 10:15 AM
stangin1996gt
Sep 21, 2015 11:01 AM
