Pipes, Boost & Juice Talk about Exhaust, Nitrous, Blowers, Turbos, Superchargers... whatever makes you go faster!
boost
Old Nov 20, 2006 | 10:31 AM
dhuskers_11's Avatar
dhuskers_11
Default boost
is it true that if you only run 4.4 psi you dont need a tune?
Old Nov 20, 2006 | 11:28 AM
nanaki's Avatar
nanaki
Retired MF Moderator
Default RE: boost
i wouldn't
Old Nov 20, 2006 | 12:08 PM
Zoie_daGT's Avatar
Zoie_daGT
Default RE: boost
I would never do ANY FI on a car w/o a tune. And btw, where did the 4.4 come from. There is no magic number for boost or tuning. Any mods are changing the peramiters of the engine and the tune w/ be off. When you add FI, you need to compensate somehow.
Old Nov 20, 2006 | 03:27 PM
dhuskers_11
Default RE: boost
andy from tmaturbo told me that i wouldnt need a tune when i start off at 4.4 psi?
Old Nov 20, 2006 | 03:41 PM
luckythirteen13's Avatar
luckythirteen13
Default RE: boost
if you run a fmu you could probably get away without a tune on such a low boost pressure but youd still have to remove total timing and that wouldnt be optimal.
why start at 4.4psi?? turbo set up right? start at 6psi and work your way up.
Old Nov 20, 2006 | 03:59 PM
nanaki's Avatar
nanaki
Default RE: boost
running a turbo at 4.4psi is like watching VHS on a 72" HDTV
Old Nov 20, 2006 | 04:02 PM
turbostang21's Avatar
turbostang21
Default RE: boost
with a fmu you'll be fine. but you will always get better performance and reliability with a good tune....so that is always what i recommend. im assuming you're considering the saleen sc since you said 4.4psi. why spend all that money on the sc etc. to save a few hundred on a good tune...that also goes for running 4.4psi....run at least 8-10psi
Old Nov 20, 2006 | 04:09 PM
Zoie_daGT's Avatar
Zoie_daGT
Default RE: boost
ORIGINAL: nanaki
Well put and +1
Old Nov 20, 2006 | 08:34 PM
dhuskers_11
Default RE: boost
no it is a twin turbo for my v6 and i am gonna turn up the boost to 8 psi when i get my fuel upgrades
Old Nov 20, 2006 | 08:48 PM
turbostang21
Default RE: boost
with 4.4psi you wont need to upgrade your stock fuel system. you will still need a fmu or a chip/tuner and a dyno tune
