Pipes, Boost & Juice Talk about Exhaust, Nitrous, Blowers, Turbos, Superchargers... whatever makes you go faster!
Best head gasket.
Old Dec 2, 2006 | 09:39 PM
BADNOTCH's Avatar
BADNOTCH
Default Best head gasket.
I am running 17lbs of boost with a 348 dart stroker motor. I have every upgrade know to man on this thing. I am getting ready to reassemble the top end and want to feel you guys out on what head gasket you think I should run. I was running mls fel pro.
Old Dec 3, 2006 | 12:24 AM
mnile9127's Avatar
mnile9127
Default RE: Best head gasket.
I hear a lot of good things about Cometic Head Gaskets.
They have copper and Multi-Layered Steel. I know
Grand National Guys running 23+psi on them.
Old Dec 3, 2006 | 12:40 AM
samseed101's Avatar
samseed101
Normally I would say Fel-Pro gaskets are great and should be enough. But if you're oging to be pushing that much boost and you want to be certain it will hold, then go for the Cometic gaskets. But I am warning you, they are expensive... like $80+
Old Dec 3, 2006 | 01:39 AM
BADNOTCH's Avatar
BADNOTCH
Yeah, my tuner told me to use cometic. I blew a fel pro but my boost retard died on me. I think I will give cometic a call monday and see what they recommend.
Old Dec 4, 2006 | 09:08 PM
BADNOTCH's Avatar
BADNOTCH
I am pulling the short block and having it o-ringed, along with the heads. I told my engine builder I want to run 25-28lbs of boost for next year. I am changing my crank pulley and putting in 96lb injectors and going to pour the coals to it.
Old Dec 4, 2006 | 09:51 PM
mnile9127's Avatar
mnile9127
OOOOHHH!!! YYEEAAHHH!!!!
Sounds like you're gonna kick some a$$.
Old Dec 4, 2006 | 10:07 PM
BADNOTCH's Avatar
BADNOTCH
I am running 10.30@135 now. I am having the tremec proshifted, full race port on the heads, downs intake full race port, 2' primary to 3 1/2' collector kooks, direct port 150 shot, and alot of suspension work done. Heres the last setup I ran.
[IMG]local://upfiles/14192/5C6D0C080F4F412DAAFE45F6B59D3FF4.jpg[/IMG]
Old Dec 4, 2006 | 10:44 PM
silver91gt's Avatar
silver91gt
cometics seep coolant if the block and head arent prepped right.
Old Dec 4, 2006 | 10:58 PM
mnile9127's Avatar
mnile9127
He doesnt have to worry about that
because he said he's o-ringing the block and heads.
Based on that, the mating surfaces will be all good.
I'm sure he has a reputable machinist doing the work.
Old Dec 4, 2006 | 11:07 PM
BADNOTCH's Avatar
BADNOTCH
I have tk racing which is on the southside of chicago doing the work. They are a quailty race engine shop, they built my original setup.
