Pipes, Boost & Juice Talk about Exhaust, Nitrous, Blowers, Turbos, Superchargers... whatever makes you go faster!
Nitrous Question
Old Dec 6, 2006 | 12:48 PM
pallidamors's Avatar
pallidamors
Banned
Default Nitrous Question
So Im trying to learn here so go easy on me lol. Why exactly would say a 200 shot destroy my engine, while a 100 shot is fine? Is it that the nitrous is causing the engine to run too lean or raise the compression too much or what?
Old Dec 6, 2006 | 02:25 PM
rez_rocket's Avatar
rez_rocket
Default RE: Nitrous Question
IMO....i think its because the stock block wasnt built for that much HP all at once. Plus i think its mostly because of people being greedy and using too much of a shot and not enough fuel, the right spark plug and too much timing.
Old Dec 6, 2006 | 03:19 PM
FullAuto's Avatar
FullAuto
Because you bought a modular motor and your pistons are made of glass.
Old Dec 6, 2006 | 04:39 PM
yellowgtstang18's Avatar
yellowgtstang18
so if i got new pistons i could run a bigger shot?
Old Dec 6, 2006 | 06:14 PM
rvoss5's Avatar
rvoss5
nitrous causes alot of pressure. the stock internals cant handle that kind of pressure.
Old Dec 6, 2006 | 07:09 PM
Zoie_daGT's Avatar
Zoie_daGT
Everything has basically been said.
1. Nitrous of any shot w/o tuning will lean out the engine and cause detonation. Say bye bye to the engine w/ that.
2. Nitrous increases the power of the engine and the combustion portion in particular. The rods in your engine will not hold up to the power. They may hold up for a little.(Note: MAY, and a LITTLE) but, you are on borrowed time w/ that big of a shot.
3. The difference in the 100 and 200 shot is the amount of nitrous that is added to the mixture. The larger 200 shot uses more nitrous which in turn makes a bigger explosion and more power. Now see number 2.
Dokilar
15
Oct 16, 2015 08:13 PM
AMAlexLazarus
AmericanMuscle.com
Oct 2, 2015 08:06 AM
AMAlexLazarus
AmericanMuscle.com
Oct 1, 2015 10:29 AM
AMAlexLazarus
AmericanMuscle.com
Oct 1, 2015 09:21 AM
treesloth
Sep 28, 2015 07:03 AM
