Pipes, Boost & Juice Talk about Exhaust, Nitrous, Blowers, Turbos, Superchargers... whatever makes you go faster!
turbo sizes
Old Dec 13, 2006 | 01:30 AM
Fuel's Avatar
Fuel
Default turbo sizes
what do u gus think the right size of turbo would be to do a single turbo kit on a 2v gt to be around the 600rwhp #
Old Dec 16, 2006 | 03:14 AM
ruffrider4403's Avatar
ruffrider4403
Default RE: turbo sizes
if ur goin with a single turbo, i would just do a s/c. a single turbo will lag to much on ur car, i'd go with a roots. but if ur thinking about a twin turbo setup, i'd go with twin t-66's.
Old Dec 16, 2006 | 01:43 PM
Fuel's Avatar
Fuel
what ar ratios would i need on the turbos
any info please
Old Dec 16, 2006 | 10:21 PM
JKBMKIII's Avatar
JKBMKIII
with a v8 a single turbo up to 76mm would be good and would not lag any diffrent then a non- roots style blower
Old Dec 18, 2006 | 03:27 AM
bransdaman78's Avatar
bransdaman78
I ♥ Acer
WUT!?!?!? 76mm are you crazy.. try 42-53 a single turbo should have 0 lag...
Old Dec 18, 2006 | 12:07 PM
88BlueGT's Avatar
88BlueGT
ruffrider.... your telling him that a single turbo will lag so he should get twin t-66's?!? Wow............... no comment [&:]
Same for jkbmk...
Old Dec 18, 2006 | 03:23 PM
turbostang21's Avatar
turbostang21
^^i'll comment. why do people comment when they have no clue what they're talking about...ruffrider for example[&:]
you'd need something like a t66 .68ar .....60somthing will be fine
first off...if you still have the non pi 4.6....you have a lot of work to do before you can think about 400whp...let alone 600whp. i know a guy with a 97 non pi gt...bolt-ons w/10psi and meth injection to make 360whp...heads are garbage and won't flow enough to make power. his same setup is worth an easy 100whp more on a pi 4.6.
btw it's hilarious to see the centri guys talking about turbo lag...centri's don't have a noticable lag since they only build boost with rpms..and they only START making boost at 3k rpms. turbo's will make FULL boost by 3-3300rpms. you call it lag because it feels like a nitrous hit when you gain an instant mountain of tq (compared to the smooth gain of a centri).turbo lag is a thing of the past (literally) with a properly matched system. while there is no such thing as ZERO lag on ANY system (single or tt), it's not noticable with the right setup made by a good turbo manufactuer (often overlooked...all turbos are not the same...not even close). and it's called foreplay on one that's not the best setup i have a t76 q trim...which is pretty damn big on a street car... and get 17psi (pump gas tune)by 3200rpms...plus it's a 347ci so it has tons of low end tq already....no lag
Old Dec 18, 2006 | 09:30 PM
Fuel's Avatar
Fuel
i am going to be doing a complete rebuild with forged iternals and am also going to go with the PI head swap
by a 60 something ar, is that on the compressor ( how about on the turbine)?
what if i did twin 50mm turbos 57 trim with a .50 AR compressor and a .63 AR turbine?
Old Dec 18, 2006 | 09:31 PM
Fuel's Avatar
Fuel
BTW i don't know anything about turbos( just know that that is the way that i want to go) so that is why i started this post and am asking so many questions
Old Dec 24, 2006 | 09:30 PM
MACH1MANIAC's Avatar
MACH1MANIAC
Damn... You must have some serious cash to do all that.. Good luck!!! Post up somepics. end its all done!
