Pipes, Boost & Juice Talk about Exhaust, Nitrous, Blowers, Turbos, Superchargers... whatever makes you go faster!
nitrous ?
Old Dec 14, 2006 | 10:31 AM
stang_girl_03's Avatar
stang_girl_03
Default RE: nitrous ?
no i am from sc
Old Dec 14, 2006 | 11:12 AM
mustangkid98's Avatar
mustangkid98
I'm not sure what kind of kit you should get for a sixer but i would only do like max a 125 shot of nitrous. You should see a big improvement with a 125 shot dunno of anyone who went higher with a sixer tho.
Old Dec 16, 2006 | 03:37 AM
nitrous_bob's Avatar
nitrous_bob
ORIGINAL: geetee03
window switch takes away the chance of puddling.
not really, rpm application doesn't change the c-factor of the intake
ORIGINAL: geetee03
dry shot is counting on your injectors to deliver the extra fuel, easier to go lean.
wet shot with window switch is safest imo.
a wet shot gets fuel from the same rail as my injectors.(unless it has an aux pump) it's delivered from the same pump, and pulled from the same source (the fuel rail) i don't see where where the chance of going lean is any different. the weak link is the pump.
dry shot is safest imo, and no need for a window switch unless you miss alot of shifts and don't lift if you miss , have stock gears and hang out in low rpms, or might have a habit of trying to spray at idle.
Sandmanbjj
Aug 21, 2015 12:38 PM
mstngdvr17
Dec 25, 2003 04:55 PM
jhogan2424
Nov 5, 2003 08:51 PM
67gt500
Aug 17, 2003 04:01 AM
