Pipes, Boost & Juice Talk about Exhaust, Nitrous, Blowers, Turbos, Superchargers... whatever makes you go faster!
car bogging
Old Jan 10, 2007 | 09:20 PM
bizarre660's Avatar
bizarre660
Default car bogging
so i have a problem. when i get on the mustang it some times does this thing like its bogging when i hit the gas. but as soon as i let off the gas itll stop and itll be fine. does anyone have any clue what it might be? i have a bunch of things done to the car like computer chip and s/c and what not so any help would be great. thanks guys
Old Jan 10, 2007 | 09:31 PM
mnile9127's Avatar
mnile9127
Default RE: car bogging
Drive the car or get it to operating temp. Cut off engine. Check one of the
spark plugs. Note the condition. Also Check the gap. You should be at
35-40 on the gap.
Old Jan 10, 2007 | 09:57 PM
bizarre660's Avatar
bizarre660
awesome will do. would you happen to think it could be a computer problem or maybe an injecter is clogged up?
Old Jan 10, 2007 | 10:25 PM
mnile9127's Avatar
mnile9127
If injector were clogged or computer, the problem wouldnt only happen once you hit the
throttle and then correct itself once you let off. I had a similar problem. Pulled my
plugs they were black. I thought it was carbon , but turned out to be oil makin me
detonate under light load.I also took off the upper intake, it wasoily on the inside.
I changed the plugs, installed an new intake gasket, and an oil separator.
The pcv system was causing blowby.I have no more problems in that area.
Old Jan 10, 2007 | 11:46 PM
bizarre660's Avatar
bizarre660
hmm sounds like what i got. the guy also put these "race spark plugs" in the car and im finding out he's sorta a monkey so that might be the prob. def gonna check it. i appreciate your help thanks.
Old Jan 11, 2007 | 12:44 AM
nismotunedgtr's Avatar
nismotunedgtr
Seafoam never hurts.
djbigskrilla
Sep 20, 2022 01:04 AM
chain
Aug 17, 2015 08:52 AM
92 5.0stang
Aug 13, 2015 06:46 AM
Milan Dragway
Aug 12, 2015 03:43 PM
ccwebb
Aug 11, 2015 06:47 PM
