Vortech drinking my engine oil - help!
Hey all - so I got a Vortech installed on my 2003 GT. Ever since, I have had engine oil dripping from my air filter (PowerPipe in the wheel well) which tells me the boost is sucking oil out of my crankcase. Is there a way to eliminate or reduce this? Would placing "stronger" PCV valves inline on each crankcase help? How about a valve cover breather?
Thanks in advance for the suggestions.
get an air/oil separator. they are about $10 at home depot then just get some fittings for it (about $5). it mounts between the intake manifold and the pcv valve. you will have to dump the oil out of it every week or so but no big deal, just pure it back into the motor
Sep 1, 2015 08:16 PM
