Pipes, Boost & Juice Talk about Exhaust, Nitrous, Blowers, Turbos, Superchargers... whatever makes you go faster!
nitrous hookup
Old Feb 18, 2007 | 06:24 PM
M1ke's Avatar
M1ke
Default nitrous hookup
those who have setup a nitrous system on a 99-04 gt, where is the fuel feed line thats at least 38psi that i need to T off of?
also if you mount the bottle in the trunk, what did you do with the floor board of the trunk? did you cut it or drill through it or what?
thanks
Old Feb 21, 2007 | 03:20 AM
CalculatedKaos's Avatar
CalculatedKaos
Default RE: nitrous hookup
Im not sure about the Fuel line as I have not installed one on a newer mustang yet. I have however intstalled many Zex kits on Hondas back in my ricer days ( I am newly converted ). As for the trunk floor, just CAREFULLY (so you dont puncture the tank or any lines) drill a hole in a safe location to run your lines then epoxy it so moisture doesnt get in. I also reccommend a Blow Down tube that way if your bottle preassure blows your burst disk you dont get a royal buzz , it'll dump it outside.
Old Feb 21, 2007 | 03:45 AM
M1ke's Avatar
M1ke
o already found out how to do it. you need the fuel rail adapter from NX.
Old Feb 21, 2007 | 10:05 AM
SleepingGT's Avatar
SleepingGT
on 99-03.5 GT's you use the shraeder valve that is on the front passenger side, 03.5-04 gt's have to either get some earlier rails or use the fuel block
Old Feb 21, 2007 | 10:26 AM
M1ke's Avatar
M1ke
i know like i said i already ordered the NX fuel rail adapter. actually its on the fedex truck for delivery so i can install the kit this weekend
Old Feb 21, 2007 | 11:39 AM
Timber's Avatar
Timber
04's have a schrader valve? I didn't see it...
Old Feb 21, 2007 | 12:29 PM
M1ke's Avatar
M1ke
no they don't. 03.5-04's dont have them. if you dont have one you need the nx adapter. it sucks because its $50
Old Feb 21, 2007 | 01:41 PM
Timber's Avatar
Timber
Yes it does suck because I feel like I need that adapter instead of using the supplied T in the kit - namely because a T will step down fuel line diameter at least at that point and I don't know what effect that will have on flow. All I know is that fuel psi shouldn't change. Fuel flow with a T is a question mark...
Old Feb 21, 2007 | 01:50 PM
geetee03's Avatar
geetee03
i like the nx adapter, its such an easy install, and it comes with a plug on the other side that i took off to put my fuel pressure sending unit on, it fit perfectly!
change your spark plugs before you put the adapter on, you need to remove it to get to one of the plugs.
Old Feb 21, 2007 | 04:16 PM
M1ke's Avatar
M1ke
ORIGINAL: Timber
yeah someone on another board told be that using the adaptor is the best way even though you have to shell out for it
ORIGNIAL: geetee03
how do you install it? im buying the adaptor by itself so idk if it will come with directions.
also how do you relieve the pressure in the fuel lines (im assuming that i will need to do this when i put the adaptor in).
btw fedex.com says the adapter is at my door : )
