Pipes, Boost & Juice Talk about Exhaust, Nitrous, Blowers, Turbos, Superchargers... whatever makes you go faster!
single or twin??
Old Feb 19, 2007 | 12:56 PM
kweb288's Avatar
kweb288
Default single or twin??
what do you think is better for a street car that will also be used at the track? a single turbo or a twin???????/ trying to make own system but cant decide between the 2
Old Feb 19, 2007 | 02:29 PM
luckythirteen13's Avatar
luckythirteen13
Default RE: single or twin??
twins are nice because you can get small turbos cheap at the junkyard. single is nice because there is a lot less tubing.
twin turbos means twin waste gates as well so there is a few more bones youll be spending. id go with a single. plenty of hp, less to fabricate, less crap under the hood and its easy to fab up the hot parts with a pair of flipped shorty headers
Old Feb 19, 2007 | 02:40 PM
kweb288's Avatar
kweb288
cool thanks, do you know anything about the selection of turbos? i was looking at a 60mm-to- 67mm turbo?
Old Feb 19, 2007 | 03:24 PM
luckythirteen13
now thats one thing i cant help you with. talk to the guys are turbomustang.com they can help you there. or if you buy a new turbo, the company that sells it can help you
Old Feb 19, 2007 | 10:31 PM
turbosha's Avatar
turbosha
hey kweb check out my photobucket. i got the diesel turbo 60mm, homemade kit. 40mm pit wastegate and turbo xs blowoff.
[IMG]local://upfiles/58140/40C1CCDB11A549AFBB255F52A29F1557.jpg[/IMG]
[IMG]local://upfiles/58140/3A53BFE5134A45908BFA18513CD6DA15.jpg[/IMG]
Old Feb 20, 2007 | 01:47 PM
kweb288's Avatar
kweb288
hey thanks for the help and pics,
Old Feb 20, 2007 | 05:38 PM
Zoie_daGT's Avatar
Zoie_daGT
Both have their advantages. Twins are smaller and run one turbo off each bank of cylinders. There is more tubing and more expensive though. A single will need to combine the exhaust gases and that is harder to do evenly. Less expensive. It is up to you which you think is best though. Good luck
mmarsh3014
Wheels & Tires
Oct 20, 2015 09:08 AM
uberstang1
Sep 20, 2015 06:42 PM
Daddys Girls GTs
Sep 14, 2015 08:46 PM
angeljoelv
SVT Forums
Sep 10, 2015 09:12 PM
Boostaddict
Lethal Performance
Sep 8, 2015 09:56 PM
