Pipes, Boost & Juice Talk about Exhaust, Nitrous, Blowers, Turbos, Superchargers... whatever makes you go faster!
superchargers
Old Feb 20, 2007 | 08:44 PM
95 svt cobra 5 speed's Avatar
Default superchargers
i want to run a procharger set up stage II intercooled system with p-1sc
15 psi
p-1sc, 3 core-spicific air-to-air intercooler
100% complete system
1.fmu fuel system
2. 255 ltr pump
3. dedicated 8 rib drive system
4. automatic belt tensioner
says the kit comes with everything u need but in order to run saftely do i need to change internals or change timing or have a dyno tune. the car is a 95 cobra minor bolt ons
Old Feb 20, 2007 | 08:56 PM
04mineralgreyGT's Avatar
04mineralgreyGT
Default RE: superchargers
Yoy will definately need a dynotune. Don't trust the tune that comes with the kit. My tune that came with my kit was so rich and the fuel curve was so f*cked up I was only making 250 rwhp and 310rwtq. I had it dynotuned and it put down 370rwhp and 380 rwtq. I don't really know the limitations of the 5.0 block but psi isn't what kills engines, it's the hp. I would venture to say that with 15 psi you'd be pushing it really close to blowing your factory shortblock.
Old Feb 20, 2007 | 09:02 PM
what psi do u run
Old Feb 20, 2007 | 09:16 PM
SSKiller's Avatar
SSKiller
04 is right....it isn't the psi that kills the stock shortblock.....however it isn't the HP either. It is the high RPM's and horsepower that kill them. Read this article on turbomustangs.com. They know what they are talking about.
http://www.turbomustangs.com/techart...stockblock.php
Hope this helps.
Old Feb 20, 2007 | 11:39 PM
FoxGT's Avatar
FoxGT
Will depend on what fmu they intend on using. Most companys provide on that will make your car run rich so you won't get as much power, but it will be safe. If you want max power and great mileage get an fpr & a tune, but the car will run perfectly fine with the fmu. I ran a 10:1 fmu & 12psi on my car for 2 months, the only problem I had was a seal from one of the tubes blowing off. Easily fixed with a little more torque on the clamp. I sold the car after 2 months, last I heard from the owner he's had no problems with the engine yet.
GimpyHSHS
19
Dec 19, 2023 01:12 PM
AMAlexLazarus
AmericanMuscle.com
Oct 1, 2015 09:21 AM
col2560
Sep 25, 2015 08:59 PM
