Pipes, Boost & Juice Talk about Exhaust, Nitrous, Blowers, Turbos, Superchargers... whatever makes you go faster!
Question
Old Mar 13, 2007 | 03:45 AM
hawks05's Avatar
hawks05
Default Question
Will it create a problem if i hookup the procharger setup but do not run the belt around it untill i can get it to dallas to get it tuned basically everything but the injectors, plugs, and belt would be installed ?
Old Mar 13, 2007 | 02:47 PM
Reed44's Avatar
Reed44
Default RE: Question
You should be able to put everything on except the injectors, including the belt. A supercharger only creates boost under load. So as long as you drive it easy, your motor will never know its there. The only reason why you cant put the injectors on yet is because it will run rich. Did you get a new fuel pump?
Old Mar 13, 2007 | 03:11 PM
hawks05's Avatar
hawks05
yep i already installed my fuel pump
Dokilar
15
Oct 16, 2015 08:13 PM
AMAlexLazarus
AmericanMuscle.com
Oct 2, 2015 08:06 AM
AMAlexLazarus
AmericanMuscle.com
Oct 1, 2015 10:29 AM
AMAlexLazarus
AmericanMuscle.com
Oct 1, 2015 09:21 AM
treesloth
Sep 28, 2015 07:03 AM
