Nitrous help Please!!!!
Ok so i just installed a zex dry kit on my 5.0 and the guy i bought the kit from said that it is for top end only and that you cant use it off the line. Is this true? Are you suppose to wait until your in like 3rd or 4th gear then try to flick the arming switch while getting ready to shift into the next gear? It just doesnt make since to me but i dont want to do it wrong any feedback would really help thanks.
What he means by top end is up in the rpm range. Don't spray it off the line without a tune. It doesn't matter about the gear your in. Make sure your at 3000 rpms or better when you spray it. Get it tuned and you can spray it off the line. It's more dangerous to spray it in 5th running 150 than anything. Don't listen to that guy, you can spray it when ever you won't to just don't spray it off an idle unless you have a tune.
ORIGINAL: nasty50
i don't know about a tune.....i spray a 100 shot in mine with mt drag slicks and its been fine for me. just make sure you retard the timing so you don't get any detonation
