Pipes, Boost & Juice Talk about Exhaust, Nitrous, Blowers, Turbos, Superchargers... whatever makes you go faster!
Help..Is This Normal?
Old May 7, 2007 | 03:35 PM
diesel1's Avatar
diesel1
Default Help..Is This Normal?
I just bought a 96 cobra... It has an O/R exhaust.. I get a pretty strong exhaust smell in the car while driving.. A mechanic told me that this was normal(not having cats) What do you guys think? I have no prior experience with O/R pipes. should I get some cats put on, or pray I don't pass out at the wheel?
thanks
Old May 7, 2007 | 03:45 PM
Sap's Avatar
Sap
Default RE: Help..Is This Normal?
Sounds like an exhaust leak to me, you should never smell fuel or exhaust in the cabin.
Old May 7, 2007 | 03:51 PM
diesel1's Avatar
diesel1
how can I have it tested for a leak? any sure way to tell
thanks
Old May 7, 2007 | 06:31 PM
skielk's Avatar
skielk
I would first start by looking at the exhaust system you might see a black area in your exhaust which is prob. where your leak is. You can also feel the exhaust leaking out where ever it is just don't get burned
Old May 8, 2007 | 08:48 AM
Dingo0079's Avatar
Dingo0079
when do yousmell it while driving or sitting at a light? My exhaust smells pretty strong without the cats but I only smell it when I stop.
Old May 8, 2007 | 12:52 PM
diesel1's Avatar
diesel1
I live in the city, so I smell it almost all the time (stop and go traffic).. If i'm in the car for more than 40min I have a headache. looked into cats last night. any thoughts on a brand.
Old May 8, 2007 | 02:22 PM
r.barn's Avatar
r.barn
+1 on the exhaust leak
give all your header bolts a turn, i bet some are loose.
used to get super strong exhaust smell also, tracked it down
it slightly loose back header bolts
Old May 8, 2007 | 07:08 PM
fiad06's Avatar
fiad06
unless you exhaust is dumped there is no reason for you to smell it inside the cabin.....you prob have a huge leak in ur exhaust
Old May 8, 2007 | 11:40 PM
Texas5.0's Avatar
Texas5.0
ORIGINAL: diesel1
Thats bad man... get it fixed ASAP.
Old May 9, 2007 | 02:28 AM
wmill2009's Avatar
wmill2009
+1 on Texas...it's not a good thing if you get headaches from it. since it does have O/R exhaust, it's normal to smell it a little bit, but not enough to give you a headache.
