Pipes, Boost & Juice Talk about Exhaust, Nitrous, Blowers, Turbos, Superchargers... whatever makes you go faster!
Prochager Questions
Old May 8, 2007 | 01:37 AM
Texas5.0's Avatar
Texas5.0
Default Prochager Questions
I just bought a trick flow upper an lower (still in the box), 75 MM mass air, 70 MM throttle bodyand 24 pound injectors for 650 bucks. It was such a good deal that I could not pass it up. This does change my Kenne Bell plans though. It looks like I will be headed the Pro Charger way instead.
So is that set up enough to run 9-10 pounds of boost? What else will I need to change if anything?
Old May 8, 2007 | 02:53 AM
newb2000GT's Avatar
newb2000GT
Default RE: Prochager Questions
I'm not sure if 24#'ers will be enough and either way you should consider your fuel pump plans.
Old May 8, 2007 | 05:58 PM
Texas5.0's Avatar
Texas5.0
What size fuel pump would I need? I am only going to run 9-10 pounds of boost.
Old May 9, 2007 | 06:49 PM
newb2000GT's Avatar
newb2000GT
I run a 255lph with 42# injectors with on 8 psi.
Old May 9, 2007 | 07:00 PM
bighungrymatt's Avatar
bighungrymatt
yea 24# injectors wont be big enough for 9-10 pounds boost. I run 7psi on my procharger with 24# injectors and my injectors are maxed out...
Old May 9, 2007 | 08:51 PM
Texas5.0's Avatar
Texas5.0
bighungry
With that setup what kind of numbers are you seeing?
Old May 10, 2007 | 12:33 AM
bighungrymatt
texas5.0, I dynoed at 337rwhp and 378torque, I still have stock heads and intake... I thought that was quite an improvement from 210rwhp stock!
Old May 10, 2007 | 12:58 AM
Texas5.0's Avatar
Texas5.0
ORIGINAL: bighungrymatt
Thats awesome. I will be running a trickflow upper and lower. I wonder what I will see.
Old May 10, 2007 | 01:24 AM
bighungrymatt
hopefully around 400+, but you might want to get bigger injectors than 24#, my tuner told me if I upgraded to 42# and 10lbs boostI would break 400rwhp
Old May 10, 2007 | 09:08 AM
nanaki's Avatar
nanaki
Retired MF Moderator
you car didn't have 210RWHP stock, maybe at the motor, but not the wheels.
