Pipes, Boost & Juice Talk about Exhaust, Nitrous, Blowers, Turbos, Superchargers... whatever makes you go faster!
Intake/MAF problem
Old May 14, 2007 | 05:59 PM
tommy2273boy's Avatar
tommy2273boy
Default Intake/MAF problem
okay,
so im going up to 11-12#s for the P1SC and I baught an 80mm MAF and a 4' adaptor plate to make it fit on my car.
before I put the gasket between them, it was blowing alot of air out. Now the gasket is in, its still blowing air between the two, but not as much.
how bad will this effect my boost and can somthing like that hurt my engine?
yes, its a ghetto-riged intake and my MAF is in the same location as if it was a normal CAI on a stock car....not in the fender like Prochargers kits are supposd to.
any help would be great!
thanks!
Old May 15, 2007 | 11:12 AM
OV10stang's Avatar
OV10stang
Default RE: Intake/MAF problem
I had the same problem(my old plastic maf body was warped). I have a PMAS Pro Tube now, no more problems.
http://www.jdsperformance.com/index....m&inmake=0
Old May 15, 2007 | 11:49 AM
AdderMk2's Avatar
AdderMk2
Banned
why do people make simple projects, really really difficult???
remove the rubber gasket, and RTV the sumbitch.... let it dry and it wont leak
Old May 16, 2007 | 10:38 AM
tommy2273boy
thanks, but not for 255!
and the gasket helps and not as messy as silicone.
Old May 16, 2007 | 10:56 AM
AdderMk2's Avatar
AdderMk2
Banned
you shouldnt make a mess if you know what your doing
Old May 16, 2007 | 12:07 PM
tommy2273boy
I can slip in a new gasket, I'd have to unstick and clean the silicone
but thanks guys
Old May 16, 2007 | 12:56 PM
samseed101's Avatar
samseed101
ORIGINAL: tommy2273boy
Do you realize that you are using a draw through MAF for a blow through setup? $255 is not that much to spend to get the right MAF for your application.
Old May 16, 2007 | 01:55 PM
newb2000GT's Avatar
newb2000GT
ORIGINAL: samseed101
+1. What's $255 to do it right?
Old May 16, 2007 | 05:49 PM
redstanger's Avatar
redstanger
i know a guy in nebraska that actually used a 2005 mustang gt MAF on his 04 mach 1 with D1 (it was a procharger).It works better thana 1999-2004 MAF meter and worked better with a blow through system. He is running 14psi on it.
Seanam
Oct 4, 2015 10:15 AM
marc954
Sep 29, 2015 03:05 PM
mdj89
Sep 23, 2015 08:49 AM
stangin1996gt
Sep 21, 2015 11:01 AM
Big Al's 03
Mach 1 Section
Sep 21, 2015 07:59 AM
