Pipes, Boost & Juice Talk about Exhaust, Nitrous, Blowers, Turbos, Superchargers... whatever makes you go faster!
Before Nitrous
Old Jul 3, 2007 | 02:34 PM
Kielianaire's Avatar
Kielianaire
Default Before Nitrous
What should i build up on my engine before getting the nitrous just to be safe?
Old Jul 3, 2007 | 03:03 PM
samseed101's Avatar
samseed101
Default RE: Before Nitrous
Depends on what you're getting for a kit and how many HP you're looking to gain. In any scenario, it wouldn't hurt to get a new fuel pump. You may also be looking at new injectors as well (again, depending on the setup.)
Old Jul 5, 2007 | 11:52 PM
96mod289's Avatar
96mod289
you got to give us more info on what you are planning
Old Jul 6, 2007 | 06:51 PM
nitrous_bob's Avatar
nitrous_bob
if the fuel pump i more than 7 years old or has over 90k on it, get a better one
also run a msd box
thats about it, if the cra runs fine now, you'll have no probs, the fuel and spark upgrades are just for safe measure
if it doesn't run right, adding hp won't help it in whatever way you make it
Old Jul 6, 2007 | 07:47 PM
Frostbitten's Avatar
Frostbitten
Yea make sure its running optimum performance first. Youll need copper core spark plugs and I would recommend going one stage colder heat range. Nitrous works better and safer with a high flow exhaust. The better the exhaust, the more power you will make. Change the fuel filter and run a can of injector cleaner through the tank before you install the kit.
Sandmanbjj
Aug 21, 2015 12:38 PM
mstngdvr17
Dec 25, 2003 04:55 PM
jhogan2424
Nov 5, 2003 08:51 PM
67gt500
Aug 17, 2003 04:01 AM
