Pipes, Boost & Juice Talk about Exhaust, Nitrous, Blowers, Turbos, Superchargers... whatever makes you go faster!
18 PSI
Old Aug 7, 2007 | 01:18 PM
mlax's Avatar
mlax
Default 18 PSI
I am going to try to get 18PSI out of my Vortech S-trim. In doing so what do I need in the blow-off category? Would the "Mondo" blow off valve work? I don't know much about this. Thanks.
Old Aug 7, 2007 | 01:24 PM
nanaki's Avatar
nanaki
Retired MF Moderator
Default RE: 18 PSI
you're not going to get 18psi out of your S trim. don't bother. the blower falls on it's face at 16psi over 5500rpm.
Old Aug 7, 2007 | 03:19 PM
samseed101's Avatar
samseed101
Default RE: 18 PSI
Besides the whole "18 PSI issue" isn't the vortech typically setup as a draw through system?
Old Aug 7, 2007 | 03:29 PM
nanaki's Avatar
nanaki
Default RE: 18 PSI
i didn't even catch that. i'm assuming he meant bypass.
Old Aug 7, 2007 | 03:33 PM
samseed101's Avatar
samseed101
Default RE: 18 PSI
ORIGINAL: nanaki
LoL, I was thinking maybe he meant bypass as well. But then again, if he's trying to run 18 PSI, why not throw a BOV on there for the hell of it. Add a nice 200 dry shot and he's good to go!
Old Aug 7, 2007 | 05:12 PM
mlax's Avatar
mlax
Default RE: 18 PSI
If 16 is all I can get than I am fine woth that. With that said do I still need to upgrade the BYPASS?
Old Aug 7, 2007 | 06:10 PM
nanaki's Avatar
nanaki
Default RE: 18 PSI
wouldn't be a bad idea
Old Aug 7, 2007 | 07:41 PM
Sap's Avatar
Sap
Default RE: 18 PSI
Mondo bypass would be a good choice at that PSI. What kind of intercooling/meth injection you planning on?
Old Aug 7, 2007 | 07:52 PM
mlax's Avatar
mlax
Default RE: 18 PSI
I have the Vortech aftercooler setup already. What other parts are required with the Mondo bypass valve?
Old Aug 7, 2007 | 08:07 PM
luckythirteen13's Avatar
luckythirteen13
Default RE: 18 PSI
i wouldnt even try for 16psi with a s-trim.
t-trim is calling your name
