Pipes, Boost & Juice Talk about Exhaust, Nitrous, Blowers, Turbos, Superchargers... whatever makes you go faster!
Help with fpss install
Old Aug 8, 2007 | 11:39 PM
wwmost's Avatar
wwmost
Default Help with fpss install
ok im ordering my nx fuel block tomarrow along with my fpss. im going to have my fuel pressure guage hooked up to one hole on the fuel block and my fuel line for my nitrous in the other. how many ports does the fuel block have? how can i hook up my fpss now? can i just put it inbetween my sending unit for my gauge? and also, what psi fpss do i need to get? thanks
also ive heard of people having problems with their switch because it makes the nitrous go on and off when the nitrous hits and looses fuel pressure for a second. how do i stop this from happening? i think its just where you place the fpss right? im not going to put it inbetween my fuel solonoid and fuel block cuz im pretty sure that will cause my fpss to go crazy
sorry for all the questions
Old Aug 9, 2007 | 07:58 PM
nitrous_bob's Avatar
nitrous_bob
Default RE: Help with fpss install
you can get brass fittings to split it at any spot you wish. use a "y" if you can find it but you won't, if it's not flowing use a tee, save the unsplit port for the line that flows, tee the 2 acc's that don't flow but sense pressure
remember a tee doesn't have to go inline......it can go any way you want and can make a piece more accessible.
Old Aug 9, 2007 | 09:45 PM
wwmost's Avatar
wwmost
so i can pretty much put the fpss on any pressurised fuel line?
mtgldr
Feb 3, 2024 09:00 PM
BOBCATJACK
Sep 14, 2015 02:18 AM
Sep 10, 2015 08:39 PM
