Pipes, Boost & Juice Talk about Exhaust, Nitrous, Blowers, Turbos, Superchargers... whatever makes you go faster!
Timing problems HELP!
Old Aug 13, 2007 | 07:54 PM
blown/ho's Avatar
blown/ho
Default Timing problems HELP!
Hey fellas, im trying to get my car some what drivable, i had installed a procharger p1sc intercooled ki, now i need to retard the timing! Can anyone help me out here? my car backfires when im gettin on it? i never messed with the timing but i thing the garage advanced it a little a while back when i was trying to pass emissions. I need some help her! i want to start fresh. i got number 1 TDC i have the plugs gapd at .35 now where do i go from there? i know i have to disconnect the little plug in the wireharness before i do the retard on the timing? but thats all i know? can anyong give me so help?
Thanx fellas.
Old Aug 13, 2007 | 09:08 PM
bone5.0's Avatar
bone5.0
Default RE: Timing problems HELP!
how much boost are you running. all you need to do is loosen the distributor hook up a timing light start the car point the timing light at the balancer turn the distributer til the timing pointer is hitting between 6 or 8 degrees depending on the boost.
Old Aug 13, 2007 | 09:47 PM
samseed101's Avatar
samseed101
You're not using platinum plugs by any chance are you? Or are you using copper ones?
Old Aug 14, 2007 | 01:18 PM
blown/ho's Avatar
blown/ho
Im using a 8lb pully and im running autolite plugs. Now my one buddy said to start fresh on the timing, said get number 1 TDC and go from there. But once i get number 1 TDC then what do i do?
Old Aug 14, 2007 | 02:04 PM
samseed101's Avatar
samseed101
Did you pull out the distributor for some reason during the installation? I don't see any reason to go through all of that if you never touched anything other than adding a supercharger. Just follow these steps here to retard the timing.
Old Aug 15, 2007 | 10:40 PM
blown/ho's Avatar
blown/ho
Yea i figured that!!! i got it! all i needed was a good timing gun and remove the chip in the harness! i got it. I set the timing a 8* do you think i should go lower? o and my buddy said it wouldnt hurt to run platnum plugs?!?!
djbigskrilla
Sep 20, 2022 01:04 AM
Cin K
Aug 31, 2015 07:31 AM
stormesixx
Aug 25, 2015 09:11 AM
1st 4 eyed fox
Aug 24, 2015 06:56 PM
KEM Motorworks
Aug 14, 2015 10:13 PM
