Pipes, Boost & Juice Talk about Exhaust, Nitrous, Blowers, Turbos, Superchargers... whatever makes you go faster!
The Bird is almost ready
Old 08-15-2007, 06:42 PM
393Bird
393Bird's Avatar
Default The Bird is almost ready
I have been busy doing the last mod that I plan on doing to the Bird. I decided to step the 393 up a little with a Vortech YSi. There is no kit for this, plus I am doing a blow through carb setup, so it took a while with some fabrication required.
Here is a shot.
Full Supercharger Install:
http://members.tccoa.com/392bird/superchargerinstall
Play time this weekend.
393Bird is offline
Old 08-15-2007, 09:02 PM
newb2000GT
newb2000GT's Avatar
Default RE: The Bird is almost ready
Sweet!
newb2000GT is offline
Old 08-16-2007, 11:39 AM
turbostang21
turbostang21's Avatar
dayumthat looks great!! keep up the good work! time for another mag shoot eh
turbostang21 is offline
Old 08-16-2007, 08:36 PM
luckythirteen13
luckythirteen13's Avatar
whats that braded line going into the shock tower?
luckythirteen13 is offline
Old 08-17-2007, 06:27 AM
393Bird
393Bird's Avatar
The braided line is the gas line
393Bird is offline
Old 08-18-2007, 01:06 AM
Shawn02GT
Shawn02GT's Avatar
that is a badass car, any predictions on how much it will put down at the wheels?
Shawn02GT is offline
Old 08-19-2007, 07:12 AM
393Bird
393Bird's Avatar
ORIGINAL: Shawn02GT
Thanks... I plan to switch to E85 this Winter, which will give me 105 octane, and a very cool intake temp. When that is done, I am looking for 700+ . Will most likely hold it down to around 600 till then.
393Bird is offline
Old 08-19-2007, 01:32 PM
luckythirteen13
700flywheel or at the tires?
and i would imagine your changing gears with that much hp correct? 4.30 is pretty steep
Old 08-19-2007, 03:19 PM
393Bird
393Bird's Avatar
On E85, 700+ at the wheels. Yes, I will be changing gears for sure. 4.30 is a great compromise gear for street and 1/8th mile now, but will need changed to something a little tamer for my expected new trap speeds. I am traping 93 in the 1/8th now @ about 5,200 rpms. I am looking for 105-110 in the 1/8th when completed. May tame down the converter stall also. This should make cruising a lot better, even with the E85.
393Bird is offline
Old 08-20-2007, 05:51 AM
contentsunderpressur
contentsunderpressur's Avatar
Beautifull car! Very very clean under the hood. I see you took your time and paid attention to detail! It really paid off.
contentsunderpressur is offline
Quick Reply: The Bird is almost ready
