Pipes, Boost & Juice Talk about Exhaust, Nitrous, Blowers, Turbos, Superchargers... whatever makes you go faster!
Nitrous problems
Old Sep 1, 2007 | 10:27 PM
wwmost's Avatar
wwmost
Default Nitrous problems
Well i got everything hooked up today after waiting for all my parts to come in. i have a zex wet kit and msd window switch. ok well i hooked up the window switch today and now everytime the window switch doesnt supply the ground, below 3500 where i have it set, it leaks fuel then my idle starts rising because its leaking fuel then drops when it gets passed 3500 because the window switch turned on the unit. so i just tried to bypass the window switch and it happens every time the solinoids are off and the car is running it seems to leak fuel passed the solinoids. I JUST PAID ZEX FOR A WHOLE NEW BOX!! BRAND NEW, is my problem the solinoids? when i turn the box on, or the solinoids, it stops leaking. i havnt tried nitrous yet, and im not going to until i get it tuned so i dont know if that leaks also. all i know now is the fuel. help???
Old Sep 2, 2007 | 02:30 AM
bryanec's Avatar
bryanec
Default RE: Nitrous problems
The noids should NEVER leak anything period, except when it is engaged. If you have the digital window switch, make sure you are using the yellow wire and not the gray one.
[align=left] [/align]
Old Sep 3, 2007 | 03:26 PM
nitrous_bob's Avatar
nitrous_bob
i don't see where the window switch has anything to do with it
did you use teflon TAPE instead of teflon paste ??? if you did go buy another box cuz you plugged your selonoids open
i can't think of anything else
Seanam
Oct 4, 2015 10:15 AM
mdj89
Sep 23, 2015 08:49 AM
kachuy10
Sep 22, 2015 01:27 PM
stangin1996gt
Sep 21, 2015 11:01 AM
Big Al's 03
Mach 1 Section
Sep 21, 2015 07:59 AM
