Pipes, Boost & Juice Talk about Exhaust, Nitrous, Blowers, Turbos, Superchargers... whatever makes you go faster!
Zex nitrous programming problems HELP
Old Sep 24, 2007 | 06:59 PM
dukeme's Avatar
dukeme
Default Zex nitrous programming problems HELP
I have installed a ZEX wet nitrous system in my 91 stang. It seems that every time I try to program it, it stays red...The programming light that is. Everything is hooked up correctly I know that for sure. 1. Turn on ignition 2. Arm nitrous 3. Go to nitrous controller and depress button once. 4. Go back to drivers seat and depress gas peddle to the floor for 10 seconds. What is next? Thanks
[align=left] [/align]
Old Sep 25, 2007 | 12:34 AM
Willem_Black's Avatar
Willem_Black
Default RE: Zex nitrous programming problems HELP
After that step the light should be flashing red/green. Then you turn off the kit, then turn it back on. The light should be green. Then you floor the accelerator a couple times to see if you can hear the solenoids open. If you can't get the light to flash, I'm willing to bet you're not hooked up to the tps sensor correctly. Double check that.
Seanam
Oct 4, 2015 10:15 AM
mdj89
Sep 23, 2015 08:49 AM
kachuy10
Sep 22, 2015 01:27 PM
stangin1996gt
Sep 21, 2015 11:01 AM
Big Al's 03
Mach 1 Section
Sep 21, 2015 07:59 AM
