Pipes, Boost & Juice Talk about Exhaust, Nitrous, Blowers, Turbos, Superchargers... whatever makes you go faster!
Boost-A-Pump Question??
Old Sep 25, 2007 | 06:25 PM
4.6LPoppy's Avatar
4.6LPoppy
Default Boost-A-Pump Question??
Why 20 amp or why 40 amp?? My tuner says he thinks I need a boost-a-pump before we dynotune. He doesn't think the pump will send enough fuel for my boost and possible NOS use. I see that there are 20 and 40 amp versions and don't understand which is for what. Here's what I have if it helps to answer. ALSO, do you agree that I need it? Sorry if the answer is obvious. I just don't know. Thanks.
2000GT, alum Teksid Cobra block, Cobra crank, dished forged pistons, forged h-beam rods, 2 valve,ported/polished, but stock PI heads/cams, 62lb Siemens injectors, Aerommotive fuel regulator, 1/2" fuel lines/billet rails, 03/04 Cobradual fuel pump in Cobra tank,Procharger P1SC w/ 3.1" pulley (15lb boost pulley), Bullit intake/throttle body, 90mm Lightning MAF, will use NOS in s/c tube to cool charge air (prob 75 shot).
Old Sep 25, 2007 | 07:59 PM
smokinsi's Avatar
smokinsi
Default RE: Boost-A-Pump Question??
My tuner also told me that i needed a boost a pump.He said it was to make sure that you dont run lean, with the supercharger. I only have 42lb injectors and i dont have as much engine work as you so im guessing the same would go for your setup too
Old Sep 25, 2007 | 08:16 PM
02TTGT's Avatar
02TTGT
it really depends how much power you are looking for
Old Sep 25, 2007 | 11:13 PM
4.6LPoppy's Avatar
4.6LPoppy
ORIGINAL: 02TTGT
Tuner says we will end up with about 550-560 RWHP using a moderately aggressive tune. I don't want to tune/run it at 100% capacity. Just don't want the fuel supply to be the weak link. HOW ABOUT THE 20 amp vs. 40 amp issue? What is the difference or application of those two boost-a-pumps?? Anyone??
Old Sep 26, 2007 | 05:00 AM
contentsunderpressur's Avatar
My tuner told me the same thing. He told me to get the 40A pump because it put out more so I did. He said there's no since in getting the smaller one and just having to replace it later. Funny thing is that I have the svt 255 lph focus pump and the boost a pump turned all the way up and still hit 98 % duty cycle with 434 rwhp.
Old Sep 26, 2007 | 06:26 PM
4.6LPoppy's Avatar
4.6LPoppy
ORIGINAL: contentsunderpressur
I guess that whenever you upgradea partto not be the limiting issue, then some other partbecomes the limiting issue!
Dokilar
15
Oct 16, 2015 08:13 PM
AMAlexLazarus
AmericanMuscle.com
Oct 2, 2015 08:06 AM
AMAlexLazarus
AmericanMuscle.com
Oct 1, 2015 10:29 AM
AMAlexLazarus
AmericanMuscle.com
Oct 1, 2015 09:21 AM
treesloth
Sep 28, 2015 07:03 AM
