Pipes, Boost & Juice Talk about Exhaust, Nitrous, Blowers, Turbos, Superchargers... whatever makes you go faster!
please need help with nos
Old Oct 2, 2007 | 08:22 PM
bignickwaite's Avatar
bignickwaite
Default please need help with nos
ok i have a 91 5.0 i just bought a nitrous kit for it . its a wet kit . where do i get the fuel from thats supposed to be from the fuel rail? do i have to tap into it ? or what? if anyone know where i can get some pics or onfo on this it will be apperciated .if anyome has some pics of where they mounted the silonidstoo ?also does the peice that holds the jets the Y peice where in the intake does that go in the plastic/ruber intake tube? thanks again nick
Old Oct 2, 2007 | 08:26 PM
sprayed306's Avatar
sprayed306
Default RE: please need help with nos
It needs to get hooked up on the chrome fuel line or shrader valve,up by the motor
[IMG]local://upfiles/77760/E64913BC16BB45B4AEF3190A70FE458D.jpg[/IMG]
Old Oct 2, 2007 | 08:30 PM
jtmustang's Avatar
jtmustang
is that off the place for the schrader valve or am i lost,i also am new to the nos scene and have a wet 100 shot to hook up to. sorry and thanks
Old Oct 2, 2007 | 08:41 PM
sprayed306's Avatar
sprayed306
yes its off the schrader valve ,i just have a fuel press gauge inline with the nitrous fuel feed line
Old Oct 2, 2007 | 08:44 PM
sprayed306's Avatar
sprayed306
you might be able to see it better in this pic
[IMG]local://upfiles/77760/FF462814C47E4D9AADC0FB2A8D37C9EE.jpg[/IMG]
Old Oct 2, 2007 | 08:53 PM
jtmustang's Avatar
jtmustang
thats cool does it seem to give u a good reading as i dont know why it wouldn't.thanks man i think that i will do that if all works good
Old Oct 2, 2007 | 08:58 PM
sprayed306's Avatar
sprayed306
ORIGINAL: jtmustang
The gauge works perfect and is accurate
Old Oct 2, 2007 | 09:00 PM
jtmustang's Avatar
jtmustang
cool i will keep that picture in my head for when i do mine
by the way sprayed306 what exactly is done to your motor
Old Oct 2, 2007 | 09:02 PM
sprayed306's Avatar
sprayed306
ORIGINAL: bignickwaite
on a wet kit you want it after the maf sensor,i usually put the nozzle 4-6 inches away from the throttle body
[IMG]local://upfiles/77760/162430D64E724B21A34F4ACFAE14083C.jpg[/IMG]
Old Oct 2, 2007 | 09:07 PM
sprayed306's Avatar
sprayed306
ORIGINAL: jtmustang
dss 306,150 shot,comp cam xe274hr 555/565,ported afr 185's,1.6 rr's,70mm tb and the rest of the basic bolt ons
