Pipes, Boost & Juice Talk about Exhaust, Nitrous, Blowers, Turbos, Superchargers... whatever makes you go faster!
Old Oct 29, 2007 | 03:47 PM
jim2312gt's Avatar
jim2312gt
Default ????????
I just bought some 4:10 racing gears brand new, but i havent recieved them yet. I called someone to get a quote to install them and he said that i would need a bunch of things with the gears...... is this right or should the gears come with everything i need??? he said if i bought everything fro mhim and had him install it would be $650-700??? is this good or bad?
Old Oct 29, 2007 | 03:55 PM
GearJammer78's Avatar
GearJammer78
Default RE: ????????
that sounds bout right for gears and install. I paid 650 for 3.73 with install.
Old Oct 29, 2007 | 07:34 PM
P.S.I.cho's Avatar
P.S.I.cho
ya i think i paid around 600 for mine so 650-700 isnt too far off
Old Oct 30, 2007 | 02:54 AM
Willem_Black's Avatar
Willem_Black
Do you mean 650-700 for just the additional parts and install? Or for gears, parts, and install? If it's just additional parts and install you're getting screwed over. Other than the bearing kit and a couple quarts of oil I can't think of anything else that would be necessary. And together those are only around 100 or so, which means you are paying another 600 for the install of just some gears. I'd ask him to tell you exactly what all you will be getting in detail if I were you.
To put it in perspective, most people on here say gears should run anywhere from 200-400 for the install. I got a quote on my as yet to be installed gears for 340. And that is includingthe lsd I'm still saving for. So gears should be a bit less. You should first ask that guy to break down all you are going to be getting, and then call around and get a couple more quotes. Don't just settle on the first mechanic for anything, not unless you knowand trust them and thier work.
Old Oct 30, 2007 | 03:13 PM
P.S.I.cho's Avatar
P.S.I.cho
if its an 8.8 rear end with posi, its more, the labor is a bit longer, you may need to rebuild the differential , you have to put in limited slip additive, if its done right they always check for bearing preload, back lash and properly shim it too
Old Oct 30, 2007 | 03:27 PM
White2000GT's Avatar
White2000GT
Depends on where you go I reckon. I bought the Motive Gear 3.73 set and had Steen Racing here in Nor**** do the install. The guy quoted me $200 for the install and the only thing he had to add that didn't come with the set was the fluid and friction modifier.
Old Oct 31, 2007 | 06:31 PM
jim2312gt's Avatar
jim2312gt
should i go with the 3:73's since its my dd or 4:10's....i have an auto
Old Oct 31, 2007 | 08:14 PM
P.S.I.cho's Avatar
P.S.I.cho
i would go with the 4.10's in an auto unless your putting down over 400 rwhp, you dont need that much gear with more horse power
Old Oct 31, 2007 | 10:39 PM
r.barn's Avatar
r.barn
$650 should include gears.
I got mine installed including them providing gears for $500
If you provide gears it should not be more than about $300.
