Pipes, Boost & Juice Talk about Exhaust, Nitrous, Blowers, Turbos, Superchargers... whatever makes you go faster!
build twin turbo
Old Mar 12, 2005 | 09:13 AM
FoxGT's Avatar
FoxGT
Default RE: build twin turbo
ORIGINAL: link1235jeff
so have u done a kit like that before
I've only done a twin setup on a v6, & on v8's the only thing i've done was a single.
ORIGINAL: FiveOhNo
the only thing i have a problem with are the headers...where do you get a set of good turbo headers (single or twin) for a decent price? the plumbing afterwards is easy, but like the above says, it's time consuming.
Buy some shorty headers. I plan on using my Mac 1 3/8" unequal shorties for mine. You could also use the stock exhaust manifolds.
so what parts do i need if i go twin and what cars can i get them from and model and year
I would recommend you try to find two turbochargers with a 60mm compressor wheel & .60A/R or close and a similar size on the exhaust. Make sure they are the same type of turbocharger, you don't want two that flow differently.
If you can try to find two turbochargers from a MANUAL thunderbird turbocoupe. I believe it is .60 if not it is close. Two Grand National turbochargers would work well too.
Old Mar 12, 2005 | 02:13 PM
FiveOhNo's Avatar
FiveOhNo
for the single turbo, where'd you get the headers/crossover pipe? everywhere i look i see em for no less than 700 bucks...any cheaper where you get em?
Old Mar 13, 2005 | 01:00 AM
FoxGT's Avatar
FoxGT
I made the headers & crossover pipe myself. I welded mandrel bends on exhaust manifold flanges. It only consisted of mandrel bends & mild steel tubing. pretty simple actully. The mandrel bends I got costed me $16 a piece, but they were thickwalls. I didn't want anything breaking. It ended up costing me around $250 for exhaust plumbing. (new parts) I'm sure you could use used mild steel & get the exhaust done with $100.
Old Mar 13, 2005 | 02:33 AM
FiveOhNo's Avatar
FiveOhNo
any pics?
Old Mar 13, 2005 | 02:40 PM
link1235jeff's Avatar
link1235jeff
where can i buy header already made for a twin setup for a 92 mustang gt hatchback
Old Mar 13, 2005 | 02:46 PM
link1235jeff
would those turbos be to much for a stock engine
Old Mar 13, 2005 | 11:00 PM
FoxGT's Avatar
FoxGT
ORIGINAL: FiveOhNo
any pics?
no, but I have one of the same piping concept on a tt v6
Can you make 2 simple welds? If you can just buy some used unequal shorty headers.
No, they are good for mid-high end power. Very good for high end power. They will create less heat & create more power than the smaller automatic ones. & it will leave room for improvements.
Old Mar 14, 2005 | 12:45 AM
link1235jeff
thank u very much for all the help!!1
lets say i get hold of some used unequal shorty headers where do i go from there
Old Mar 14, 2005 | 03:26 AM
FiveOhNo's Avatar
FiveOhNo
can you post the pics of the tt v6 headers? i'm goin single turbo, but i'd still like to seem them. thanks
Old Mar 14, 2005 | 05:29 PM
link1235jeff
so what headers would u recomand
