Pipes, Boost & Juice Talk about Exhaust, Nitrous, Blowers, Turbos, Superchargers... whatever makes you go faster!
computers
Old Nov 12, 2007 | 10:14 PM
GaryBisiniere's Avatar
GaryBisiniere
Default computers
what do you guys use for computers. i would like to build a turbo 306. and i am new to fuel injection.
thanks gary
Old Nov 13, 2007 | 08:39 AM
roughneck9725's Avatar
roughneck9725
Default RE: computers
There are a ton of choices out there. Probably the cheapest route is a stock PCM with a MAF and a chip set up for your setup. This is a simple setup that will work fine if you dont go crazy with boost. There are also a lot of aftermarket computers that are fully programmable. They are expensive, but offer infinite tuning ability. This is good to fine tune your ride or if you plan on changing parts often. They are a good choice if you have the money. Checkout AEM for one. There are many others, this is just the one that pops into my head and it plugs into the stock harness and uses stock sensors. Just do a little research (google) and you will come up with what works for you.
Old Nov 13, 2007 | 11:58 PM
cylostang's Avatar
cylostang
Two words, stand-alone, they are freaking amazing. After seeing a SA system at the races this weekend im starting every EFI build with one, amazing just amazing. The system i saw measured barometric pressure, ambient air temp, boost pressure, boost temp, all eight exhaust temps, all eight AFRs...amazing i want one, everything that can affect HP it monitors, it is worth the extra weight and money.
[align=left] [/align]
Old Nov 26, 2007 | 04:35 AM
TTGreenSN95's Avatar
TTGreenSN95
Im using the SVO epec its old style but its easy to use.just need an old laptop....
Old Nov 26, 2007 | 04:36 AM
TTGreenSN95
sorry double post im at work and the pc sucks here when it rains
i think they have a dish on the rrof for there internet.....
Old Nov 26, 2007 | 03:02 PM
P.S.I.cho's Avatar
P.S.I.cho
i would run the stock cpu. chip, maf setup, unless your going to be doing data logging and making serious power you will be fine with that, if anything you can run a piggy back system and some times save a little rather then spending the $1200 or more on a stand alone
EZFEED
May 5, 2016 08:54 PM
piotrek53
Oct 13, 2015 06:54 PM
ChampInSD
Oct 2, 2015 04:55 AM
firecoyote
Sep 27, 2015 02:37 PM
mltdwn12
Sep 23, 2015 08:54 AM
