Pipes, Boost & Juice Talk about Exhaust, Nitrous, Blowers, Turbos, Superchargers... whatever makes you go faster!
Twin turbo Problems
Old Dec 19, 2007 | 07:54 AM
86twinturbo's Avatar
86twinturbo
Default Twin turbo Problems
have aquick question I jsut installed a twin turbo setup on my fox body. I have edelbtock heads/intake, and f-cam and I have almost no vacume at idle??? I mean I have like 5-7 inches of vac. any one have any ideas I have tried everything that I know to try. The motor is fairly frersh (less than 15k) the ecar did set for awhile though. I have no idle problems or anything like that that is usually associated with a vac. leak. I have checked all the lines numerous times. I have eliminated most of them there are only a total of I thin 6 lines total. Any help wouldd be greatly appreciated.
Old Dec 20, 2007 | 04:02 PM
P.S.I.cho's Avatar
P.S.I.cho
Default RE: Twin turbo Problems
is the car idleing high whats the idle set at? if your idleing high your vaccume will be low
Old Dec 25, 2007 | 12:11 PM
mustang289's Avatar
mustang289
While I do not have a twin turbo on my mustang, I do have a 351W with a healthy cam and I too had about 8inch of HG at idle, I had to install an electric vacuum pump from summit, it was about $300 and i now have about 23inch of HG at idle...
Old Dec 26, 2007 | 11:19 PM
D_Gusler's Avatar
D_Gusler
So, did you have 22-24 IN VAC before the turbo install using the same motor?
Granatelli Sales
Mar 21, 2016 06:16 PM
mmarsh3014
Wheels & Tires
Oct 20, 2015 09:08 AM
2015Ecoboost
Sep 17, 2015 01:48 PM
angeljoelv
SVT Forums
Sep 10, 2015 09:12 PM
Boostaddict
Lethal Performance
Sep 8, 2015 09:56 PM
